Go-FOC G300 100V 300A
not really sure what’s causing the issues but setup has definitely been finnicky for me. Initially with some 56118’s I had some stutter on one motor under high current draw which then went away after a firmware reflash/redetection, but then with some 70125’s I had one set up totally normal then I had another which seemingly worked fine but then locked up and stopped working mid way through a track day, very odd behavior, motor would just vibrate back and forth on acceleration then when applying brakes it would just permanently get stuck at drawing 200 amps without moving. Eventually after 6 or so attempts at running the wizard/manual detection I was able to get it running again but definitely something I’m going to keep an eye on for some time.
I wonder if it could have something to do with the little connectors/adapters you need to use to adapt the inrunner sensor connectors to the normal jst’s, I went from getting no detections with one motor to it detecting totally fine once I reseated the connector, but this was also the same connector I used with the 56118’s that gave me no issues after initial setup.
Are you talking about those multi pin waterproof sensor plugs? I’ve got them on mine with the 56118’s.. Has David said if there’s been any changes to the esc’s?
Yup, those little connectors, for some reason unplugging it from the motor and replugging it made it detect again. No word as of yet from David on if there’ve been any particular changes but I did notice some slight pcb differences between the 2g300 and single g300
The G300 is the bomb! It works great! The cleanliness, smoothness, and lack of noise are truly incredible. It’s definitely superior to any controller I’ve tried over the years!
I had something similar happen when I was using motor detection wizard
Going through it once I got both motors to work, but after some time when I was still inputting settings and finalizing programming, one motor would not even even spin during detection
As I ran a second time because it stopped working
I’ve only run my board once, but I didn’t have a problem throughout the ride
