are you still in business ? i will like to buy one vesc maybe but not so sure now if the guy is still alive
you didnāt respond to my emailā¦etcā¦
its possible that because of the covid lockdowns in china theyāre not working rn
my english is not so great pardon me, if i am not sure what you try to explain , but to me you says its a 4.12 vesc with some modification ? i presently run the maytech 4.12 at 80A motor in a heatsink and they stay cool, but i want to upgrade to vesc 6 so i can have better braking power on my mountainboard
oh yes, i forget that thanks
he seems to be alive ,he just send me a email ,
good to hear ![]()
but i donāt know this guy so much thats why i ask to people like you from the forum , if i can trust him
yes u can, makerx is the good one out there
also i will like to see some videos of the vesc 6 pro in action
i want a vesc with enough power to stop me in a hill , i weight 235 pound with my mountainboard
Iāve got the DV6 pro in my mountainboard as well, itās been working great so far. Running 100 motor amps per side, have gotten an overcurrent fault one single time using 9 inch tires
Iāve got a DV6 pro in a race board running 120 motor amps per side on 7 inch stretched pneumatics. I did get an overcurrent fault that threw me but i switched on the āSlow ABS currentā tab and not had an issue since.
Ooh I should do that thanks for the tip. I hit it when I was going like 1mph with 9 inch tires offroad, throttling up
Sorry, is this a question? I can see youāve got the Slow ABS current tab enabled.
Increasing the absolute max current might solve the problem.
Sorry to disappear for a while, as weāve been preparing the brand new D75 and D100 recently.![]()
Hi guys, Iām having a weird issue with a brand new DV6 freshly flashed with 5.03 (it came with it from the factory, but I like to start from a clean slate). I use a PPM remote and even if itās mapped correctly, for a few % of the duty cycle AFTER the deadband (10%) is overcome, the VESC injects a negative current to the motor, making it very jerky on startup. I have a screenshot of the problem:
Detection has been fine, theyāre FS6374 190kv motors and I have the exact same setup on another board that works just fine. Any ideas?
Iāve had the same issue with my new DV6 pro, where with the same FW and settings on my previous DV6 Pro or another DV6 didnāt do it, only the new one that came preloaded with 5.3 does it.
I hope some insight is found.
To add further to the issue, I can even reproduce it trying to turn the motor with the keyboard at very low currents (3A for example, instead of trying to turn the motor, the VESC brakes) @YUTW123
