Personally, I think any ESC can benefit from a heatsink.
In my testing with the DV6, I had my motors set to 80a each and my battery set to 50/side. I was able to heat up the DV6 to about 74C after three intense hill runs at 20-30mph. This all using my combo of bergs and clevers on a belt drive board.
I only weighed around 155 at the time, and the hill varied from 10% grade up to 25 ish% grade.
If you weigh significantly more than me, ride a lot in hot temps (80F+), or do intense offroading with pneumatics, you might see some benefits from adding a heatsink. If you had an open-air heatsink I’m pretty sure it would be very difficult to ever overheat the esc, unless pulling its max amps or something like that
For anything with urethane don’t even bother - for pneumatics, above 6 inches might benefit more, but for me, I’ve never felt the need to add one. It’s not often that I hit a hill as hard as the one I tested on, for that long of a time.
In normal riding I’ve not seen it go much above 65C on bergs/clever
I am starting work on my DV6 pro video very soon, but I do not expect it to perform any differently.
I weigh closer to 200lbs and use 7inch pneumatics and not had dv6 go above 63degrees with no external heatsink. My battery dies before esc overheats. My logs show a very slow and steady increase in temp but never got close to overheating. If I had a bigger battery and could ride for longer it may creep up to levels where I’d consider extra cooling. For reference I have a 12s5p p42a pack and get around 20-25km riding hard, and up to 40 if chilling.
It is half of DV6, and the size is reduced. It is small in size and has strong performance. Much more better performance than mini foc . we call it Go-FOC SV6, and it will be available soon.
