Could someone help me understand what it is that phase filters do and what are the downsides of not having it?
phase filters are a physical hardware device thatâs enabled by default in vesc fw 5.3 . these escs dont have the hardware so you HAVE TO disable it
its under motor cfg â FOC â filters
Anyone selling any of these three in good condition?
Not yet but according to evan I just need to change firmware, I will when I get the chance, lots going on over here
I purchased it so I donât plan on rushing to provide a review of it, or opinions.
I have one of the original D75 and have got it up and running. I have an unusual problem in where one side of the esc wonât retain the sensor parameters.
I do detection, get success and see the readings. Write them to the esc, but then theyâre immediately forgotten. When I go to read them theyâve all reverted to 255. Anyone had this problem or something similar?
update
Iâve restored default motor parameters and re done detection, now the settings âstickâ. So itâs all settup and ready to run!
did you run it with 18s ?
the original d75 cannot do 18s
sorry ,18s lipo yes it can be , my question was not clear , maybe is the v2 version
makerx said this before, the original d75 has 75v fets. 18s is only possible on the new d75 which has 85v fets
is it worth it to run 18s lipo i am not convinced but i want more range , the power was already enough
also i donât see any videoâs with 18s-20s
Iâd get the d100 to run 18s
not worth the risk to me at least.
honestly until they update the webpage to reflect that, i wouldnât even risk it above 16s
the d75 is no more available on the website its strange
its out of stock yeah
save yourself the headache and get a d100
at 18s it should draw less amp ? btw i will not go more 80A battery current
sorry to ask a newbie question , do i need to buy a external bluetooth module ? i donât see any information on is website
if u want to figure it wirelessly, then yes
If you arenât going over 80 batt amps just get the d100
Itâs on a 12s settup currently.
Are you using the 5.3 fw that came on the esc?
I am having extremely inconsistent detection results on this d100 i am playing with, i cannot get it to detect the sensors properly no matter what I try
