Please let me know the best gear drive options for the Lacroix Jaws 2.0? Or should I save for the Falcon Drives? All tips and knowledge welcome
You could get boardnamics m1 at gear drives? Just email him if he has an adapter for the hypertrucks
Hypertrucks?
Yes with hypers
Pretty good option here too
Pretty sure your only options are 3dservisas gear drives, and M1-AT from Boardnamics.
Edit - Reach out to @DEEIF if you want the hypertruck BN kit. Looks like he sells them.
Check my build thread if you wanna see boardnamics. I swapped out falcon gear drives for Boardnamics because I like steel on steel straight cuts. It’s not for everyone. If you value quiet, 3d servisas is a better option.
Obviously there is the falcon drive from lacroix as well.
Yea I’ve got some! Send a dm over
Which ratio would be closest to 16-72 tooth belt drive in the bn gear drive, thanks for help
72/16 = 4.5, so you are looking for the 4.6 ratio in BN gear drive. (18t pinion, 83t wheel gear)
