9" tires initial impressions
At first I didn’t notice much difference, but on the end of the ride, 8"s no more
The maybe bad first, on asphalt at high speed I had the impression the board was less stable and was feeling it start to wobble a bit, nothing that you can’t easily control, but I just noticed I peaked just shy of 40 km/h, I usually limit it to 30~35 km/h, so I probably screwed up when setting the new ERPM limits
I also have to play with tire pressure, right now I’m at 50 PSI, which is the maximum recommend to these tires, maybe increase it a bit
@Flasher @Venom121212 @rich and anyone else that run 9"s, what pressure you guys use?
Now to the most important question:
Can I go down curbs?
Hell yeah, this curb I couldn’t on Trampas on 8", only the less steep ones, up I have to try still
Sand is also no issue, a few posts above you can see my board stuck in this very same place on 8"s, now I can even stop in the middle of it and start going again, for now the 4WD idea is postponed
Consumption seems a bit higher but I purposefully went on the worst possible terrain to test, plus the too high top speed
Overall I very much like them, just need more batteries now, I didn’t bring the range extender because I didn’t want to test two new things at the same time, but wish I did, made a wrong turn in the woods and only realized long after, made home but barely
And I was going to try the seals, but let the silicone cure a bit more and also I wasn’t looking forward to cleaning the board after
