kook
August 26, 2020, 10:10am
#861
Fuck I love bandung… cool city temperature and architecture…
If you have power to the Unity without the switch connected your anti-spark has bitten the dust… fix it?? add a loop key??
let us know WTF happens with another battery and the switch disconnected
XTLA
August 26, 2020, 10:11am
#862
Yea will check all tonight, just back from office haha
XTLA
August 26, 2020, 1:01pm
#863
I’ve tested with other unity and there’s no blinking light when connected to battery (switch is off). And unity is light up when switch is on—->normal
So it seems like something wrong with the previous unity?
XTLA
August 26, 2020, 1:34pm
#865
I think so, yea will add a loop key, need to modified the encloser also, damn unity. After all this time i didn’t know until i open the encloser today. But the battery not drain much tho.
XTLA
August 26, 2020, 1:47pm
#866
So i open it , i found this, what is this? nothing like this on the other unity
Between the 5V and MOM1
kook
August 26, 2020, 1:52pm
#867
I dunno boss…
all my unities are on the board… seems a little suspicious… can you heat it up enough to just break the solder bridge?
XTLA
August 26, 2020, 1:54pm
#868
I’ll try to remove it, gosh. QC passed
kook
August 26, 2020, 1:58pm
#869
even some flush cuts to break the solder bridge…
brother you may have unwittingly won the esk8 lottery hall of fame…
x your fingers and break that solder bridge…
then power the fukker up
fingers Xed here
kook
August 26, 2020, 2:04pm
#870
I dunno if the switch requires 5vs… seems like a hinky design to rely on a solder bridge…
I’d break that solder bridge without a moments notice… if it don’t work… you can always find a way to replace the solder bridge…
kook
August 26, 2020, 2:10pm
#871
XTLA:
QC passed
certainly an indonesian has to respect that… honestly… just fix the issue
XTLA
August 26, 2020, 2:16pm
#872
Hahahaha, i’ll fix that tomorrow.
kook
August 26, 2020, 2:17pm
#873
I have gUUd vibes you have found your problem…
please report back my brown brother
kook
August 26, 2020, 2:21pm
#875
tomorrow your time sama-sama
good luck!!! I have the gUUd vibes you have solved the issue…
just live by k00k rule #1
don’t make anything worse…
XTLA
August 26, 2020, 4:26pm
#876
Removed it, and the problem still there , sh*t
XTLA
August 27, 2020, 5:08am
#877
It’s not solder bridge btw, i think it some kind of resistor, just don’t understand why its there. And since i’ve removed it and change nothing, i was wondering should i put it back or not , it’s broken anyway and i don’t know which one to replace it, damn .
XTLA
August 27, 2020, 5:22am
#878
It’s 1st batch unity, i think later batch don’t have that bridge/resistor/whatsoever.
1st batch
Led2-Led1-5v-mom1-mom2
(5v-mom1 sort)
Later batch
(Led2-)-(led1-)-(led+)-mom-mom
XTLA
August 27, 2020, 12:07pm
#880
Yea, and need someone to explain this, no .
