Did you think you could use 11,1V to ride a skateboard?
22.2v
What is your setting on minimum input voltage on your Unity?
“Cut Off Start 20.4”
“Cut Off End 18.6”
8v - 59v
Now getting an OVER VOLTAGE fault code… VX1 still doesn’t work once through setup process…
I figured it out… the wiring on the VX1 PPM cable is opposite to the wiring in the PPM module on the Unity… once that was sorted it all works a treat!
PS… Many thanks for all the invaluable advice everyone has given me!! Presty
Tried to connect FS VX1 UART receiver cable only to find out that the Unity has only 7 pins (vs 8 pins).
How do you guys usually connect VX1 remote to Unity?
PPM or find a 7 pin jst and re pin it.
I repinned it and it’s working, thanks!
Seems a little buggy the reading and writing of configuration, specially when the remote is on it seems.
Rides really well, only thing I miss is reverse direction when full braking after a while
