Maybe next build lol
Cough MR60 cough
I know and actually our friend @frame gave me a bunch of those but the enclosure needs to be modified and I was in a hurry to try the board. I may do that later tho.
I’m sorry, i thought VTC6 had 30A discharge max current continuos but i was wrong they are 15A.
You can increase the battery current but not by much, 67A…
Well, it’s 10% more…
What app is that?
Easy Battery Calculator
Nicely done, Tamatoa!
Thanks dude, not too shabby I dare say
I have an evo and a tayto to build now
@EboardSolutions or any flux lover
What’s the Version 1 truck angles?
any reason for using 35e instead of 40t?
30˚ at both ends.
40T is 21700. In high P-group packs there is no need to use high discharge cells. Better to use lower discharge cells with higher capacity
Frederic
When will flux motion offer the 2nd gen deck and enclosure as a diy kit?
hi there, been looking all over your website, also on reviews online, but nobody would neither mention nor test the deck flex. the battery looks like it is built for some flex, I wonder how it flexes as I like me some flex - any chance to compare the flex to any evolve bamboo deck?
This deck is nowhere near evolve bamboo deck in term of flexibility. I would say that flux deck has very very little flex. On scale from 0-10 I’ll give it 1.
Edit. I am 79kg.
Depends on the weight of the rider. I’m 120kg with all the gear and there is some flex. I quite like it!
my math is a little rusty, but what are the discharge figures (continuous and peak) for this pack?
I think for the Flux AT1 80 Amps continuous , peak you could set it to 130/150 Amps
For the Flux AT2 88 Amps continuous and peak almost around the same of the AT1
But i would not put the settings in Vesc Tool over the continuous amps of 80 or 88 depending on the Flux you got.
In a couple of weens when I have more materials. Complete boards have priority
