Huh I ordered a second one. I still had to select vesc4 or vesc6 connector but this time when it arrived it had both.
After using this for a while, my main gripe is i press the mode button with my little finger when i jump…thats slightly annoying. Also not ideal for offroad boards, seeing as your have the screen facing the road when you fall. A bigger thumb wheel would be nicer, but all in all a good remote!
We have found exactly the same and @BigBen has spoken to Flipsky about it, they are changing the firmware for us and im assuming this will be available to everyone, we will make sure they make it available anyhow
Firmware to disable mode button would be great!
What are you referring to?
This, we are getting a button lock implimented
So it should be in the new firmware? Hopefully
That would be awesome! Is there any way the voltage view can be available to public too or is that just exclusive to you guys?
I’d definitely make a short vid on those new features if they come out and post it on Instagram
What wizardry do you talk of?
Apex showed a picture somewhere, where instead of a bar, it showed both the battery of the board, and of the remote, in numbers - a very helpful thing
We did?
This something either my old brain has forgotten or was a dream. ![]()
I’ve talked to them about this but they were finding it difficult to fit everything in.
They’re open to anything like this if a sensible layout can be drawn up.
Nah it was absolutely shown somewhere haha maybe it was by Lee or something but I was very excited about it being a possibility
Can anyone tell me if i would be able to use the VX4 remote with Lacroix/stormcore 60D?
will it be an easy plug and play?
Don’t like the Puck that came with board.
I’m using the vx4 on a stormcore 60D on my 4x4. Works a treat.
Does this thing have any buttons that can be used for reverse, cruise or accessories (lights f.e.)?
Can confirm. Works fantastic
Unfortunately it does not, not for accessories.
It has Cruise and reverse tho
Is the firmware with the button lock already available? What would be the latest firmware version otherwise?
The up to date firmware is 1.1. As far as I know the gear lock firmware isn’t distributed yet. Works well though.
