Hey guys,
We have been testing the new VX2 remote from Flipsky and ran into a problem.
When following the steps to connect the remote to the esc you may run into the problem of the remote doing nothing as shown here:
This problem exists due to the wiring of the receiver being wrong for 6.x.
On the Connector you will see following wiring: Red, open, White, open, Green, Orange, open, open
The Green and Orange wires are swapped by the supplier:
To fix this simply lift the plastic latches of the cables and gently remove the cable:
Then switch out the Green and Orange cable and it should be fixed.
The right order of cables is Red,open,White, open, Orange, Green, open, open:
After switching them out the remote should work properly with telemetry and everything.
Note: this is for the Model 6.x. based ESC only, on the Model 4.x. the pins of the UART are reversed and in the right order
I know most of you are well experienced builders, but i hope this little problem solving helps those who might face the same issue.
