im running a stormcore 60D+ hoyt st. puck and the flipsky 1.0 display
im getting nothing on the display at all. ive set the parameters for everything and nothing.
i dont even get a battery read out. any ideas?
Does it turn on at all? Is the VCC plug at the 3.3V pin or at the 5V pin?
it turns on. 5 pin
Might be firmware related. Don’t those things need updates
im using the new vesc tool. maybe it needs to be updated. not sure how to do that
there is no mention of it on the flipsky site
Afaik the flipshit screen is just a bad copy from @janpom’s Davega. Maybe his fw still runs on those? idk, not a lot of people use them.
Yeah that’s probably your issue. Your on 5.3 I’m guessing firmware and the display doesn’t know how to read the info. Maybe try updating the firmware with how the official Davega is
UART enabled on the Stormcore?
thats the code? do i insert that somewhere? thats not something im familiar with.
No. @bboybowzer’s comment is misleading. The flipsky display has nothing to do with the DAVEGA X.
Check that you have UART enabled on the Stormcore.
In the VESC Tool set:
- App Settings > General > App to Use: PPM and UART
- App Settings > UART > Baudrate: 115200 bps
if I remember correctly flipsky display is basically the open source davega. Roxie is a fork of that and they reported that code also broke with 5.03. Seems like packet length has changed.
Cool, wasn’t sure. Their website for the product just says based off of Davega
5.3 the latest vesc tool
That’s how it’s already set.
OK, I guess it’s not compatible with 5.3 then. Your options are:
- Wait for Flipsky to implement it. (Good luck.)
- Downgrade your VESC firmware.
- Get some other display that actually has an active firmware development.
They mean the OS Davega. That’s different from DAVEGA X.
you are about to make some money off of me. time to get the davega x. lol
