“Pack” means the female side is included as well? I’m talking mostly about the balance connector. Do we need to go purchase the corresponding female connectors?
If they are supplied, do they come with precrimped wires installed? I doubt it, but hey, that would mega awesome hehe
Yea but they vary from time to time when you place the order, I know daly is always the same but bestech is almost all the time different, even the vescs vary from maker to maker which is kinda stupid…
I’ll add a picture to show the connector packs and what they contain. They will contain, PCB side vertical and horizontal headers, cable-side housing and crimps with a couple extra ones.
I will be adding a 26-wire ribbon cable (3M cable, 26 AWG) to the store before it opens officially, so you can also get the balance wires with the same order. I will probably also offer all the connectors also as a separate products and corresponding crimps, in case you want to be more specific with them.
Balance connector is usually JST XH-series, as it’s the same that is used on Li-Po packs, connector pitch on the PCB is 2.5 mm. CAN and I/O are using JST PH-series as the intended connectors and they use 2.0 mm pitch on the PCB.
I sent request for quotes to a couple different Finnish PCB and assembly houses for batches of 100, 250 and 500.
Personally I like to use silicon cable over pvc ribion but I think that’s me been ott.
Other thing that would be nice to add th the store over time.
fuse for the balance leads.
Fish paper and rings
Kept ion tape
Temp Sensor suitable to the BMS
Nickle strips
Heat shrink
2pin ph header/plug for the temp sensor for freaks like me who added one to the pcb
I just ebayed red and black silicon stranded think I use AWG 24. I fined silicon cable holds up to heat and been crushed better not as good agains puntcher or abrasion but that’s shouldn’t be happening in a batery pack
Coming back after a while to the project, have we got yet the function where any low cell will warn the ESC via CAN and safely shut down or throttle down?
No not yet I think from what I can rember the issue is the VESC needs to accept the command. I was hoping the BMS could inject a batery cut of end command triggering the VESC to stop acceleration but still alow brakes
When the VESC BMS gets released we can add the VESC BMS communication support, so either the BMS can send cell voltage info to the ESC or the ESC can poll the cell voltage info.
I have now the payment processor signed up (they called me and we did some negotiation) and I am in the process of setting it up for the checkout process. I will be doing my own test payments first through it and then asking couple dudes from the forum to do the first real orders (do not PM me for this), so I can check that everything is working correctly.
If everything goes fine, the shop will open next week with credit & debit card payment option, with Paypal to follow at some point.
