FlexiBMS Lite - Flexible Configuration BMS w/ CAN-bus
0.5 HW is pretty much ready.
Proto boards for it are gonna be ordered on 1st of February (hand assembly sanity check boards).
I’ve checked out a couple of local accounting firms that I will get in contact with later this week. I’m planning on turning my trade name company into the llc. with a name change along it. Once I get that done I’ll start contacting PCB fab + assembly houses for quotes and start making decisions on the first zero batch production run. Running alongside that I’m gonna be doing my hand assembly boards.
I’m not quite sure how the CAN-bus will behave if you have multiple devices (>2) on it and multiple of them have termination resistors. Normally the termination resistors are only used at the end of the cable chain. So just in case I moved the termination resistor a little bit on the board and added an easily cuttable open trace, so if there is too much termination on the bus, you can just cut that little trace to disconnect the termination resistor and solder bridge it back on later if it’s needed.
