First time using spot welder, could use feedback / advice
Here’s a picture of my first attempt at building a 12S5P “trapezoid” pack parallel group. I’m using 10mm x 0.2 pure nickel. I’m wondering if I need to add 2 more connections as drawn in red for ampacity. The cells are Samsung 40T.
My plan after spot welding the nickel is to wrap the groups in shrink cover, fold the tabs down, and solder #10 awg silicone onto the ends as connections between groups and for lead wires.
Any advice or feedback would be appreciated!
You will probably got scolded for those corners :joy:
I’d direct you towards
@glyphiks
@ZachTetra
@Skyart
They are my battery porn go-to’s
Yeah hopefully that’s a test group of cells or stock pic but to answer yur question I personally would just go around the outside perimeter for the parallel groups…
But if those are.your pictures then all that over lap onto the ring protector should be cut to fit just the positive terminal… On the negative side its less an issue since there’s nothing to short out on itself…
I would add nickel in your highlighted red areas, and yes, before you proceed, please round the corners of your nickel straps. You can use regular household scissors to do this, it may extend your battery life by preventing shorting due to sharp nickel edges.
Same opinion as Skyart here. Add the nickel, round the corners… potentially you can do more of a radial pattern from where you connect to the parallel group but that would be messy, easiest is to double or triple up on the ‘tip’
Like this but ignore the dots
O - O - O
. O - O
thanks for the replies guys. Yeah i thought the corners looked a little janky so i’ll clean those up and add some more nickel as suggested
buy a box of sand and a fire extinguisher as well…
all the best
you think my battery will catch fire?
it very well could looking at your effort so far
or do you just cast shade to all newbie battery builders?
i said i would round off the corners. please tell me what else indicates to you that it will catch fire. thanks
is this billable hours?
just ignore me… you have some ecellent advice from some qualified battery builders…
I’m just a k00k…
he’ll be fine right?
@discobot fortune
:crystal_ball: Don’t count on it
buy a fire extinguisher
Hi! To find out what I can do, say @discobot display help.
@discobot fortune
:crystal_ball: You may rely on it
that’s what i fuckin thought
