We’ve been working on making some great skateboard products, but we’re hitting some design bottlenecks right now.
what are your thoughts on them? Are there any areas that could be improved? Let me know if you have any better suggestions so I can try to make a product out of it.
Hey thanks for your reply
Wheel inner diameter 92MM
outer frame diameter 104MM.
wheel inner width 55MM,
wheel outer width 61MM
and you are right, I should fill in some information
.Compatibility: evolve Truck/meepo Truck/ownboard Truck/wowgo Truck/lycaon Truck/drive/rideonsra Truck, etc.; compatible with systems belonging to the double-decker axle belt drive.
This stuff looks awesome, however the best way to get feedback is to let members of the community test it out. It looks great, but performance and durability are pretty much unknown from looking at these.
For the channel trucks, almost everyone’s moved on from springs to polyurethane bushings. Far more customizable, and aren’t subject to oscillation since the bushings are naturally damping.
I’ve seen the same parts on Reddit from someone in Hainan, so it’s probably related. Channel trucks appear to be made by “Linn”, which I haven’t heard from before.
