First DIY build diary
If you want your build to be “waterproof”. Best option is MTB style with a Pelican or similar cases top mount housing. Doesn’t matter if your BMS is waterpoof when everything else is wet. I use a knock off Pelican case and rode it through a bunch of rain without issues. Most DIY builds aren’t “waterproof”, they’re water resistant. I wouldn’t submerge them or ride them through super deep puddles.
Yeah if you’ve got water getting to your bms, you’ve got problems.
Best to plan the build so that your intention is for the bms never to get wet
In the future, i prolly have to do both anyways. So, a top and a bottom enclosure. I today woke up with the vision of having a raincover i can strap under the deck first, secure it, then another one over the deck and my feet. I also want to have fenders i can remove if not needed. I read what happened to the fenders of @Mikes_Esk8 and i think i have the solution to that problem. Ill mount them on spokes just like the ones on bikes, so the vibration energy can dissipate into movement, instead of killing the material.
Keep it simple, only do top mount box for now. Bottom enclosures doesn’t rl do a good job keeping water out unless you put in lotta work.
Um confident i can make a bottom enclosure watertight. Top Enclosure is absolutely out of the question except if i have to extend the range of my preexisting bottom enclosure.
I skimmed the thread quickly. But what are your goals for the build? Whats your desired range, and speed? I love my odachi v2, 20mm drop with 240mm hangers. 16s10p 45ah battery, reliably 40 miles range riding at very fast pace. Anything bigger you won’t be able to carry or lift into car easily.
My goals are a Deck that i can run at least 70 miles without recharging, ride offroad and carve. Its not important for me to go super fast. Like 25mph top speed is completely enough for me. The Deck should be super robust and survive multi day tours easily as well. And it must be waterproof so i can be sure that it rides in the rain just as good as on dry roads.
What cells did you use for your build? I plan using Samsung 50S cells. Id Use the new Molicel P60C cells, but it seems you cant buy them anywhere retail and i also dont know how expensive theyd be.
The odachi fits that description very well. I’ll push back just slightly and ask what’s the most amount of miles you’ve done in a day already? Only reason I ask is because I see lots of people over sizing their batteries but never ride past 20 or 30 miles. I don’t see many people riding more than 50 miles continuously? But if you’re really doing that then large batteries are the way to go.
Riding around 25mph you might expect to see 30 wh/mi on the high end. So very rough back of the napkin math to get 70 miles at 30 wh/mi you might need 2,100 wh minimum battery.
For me, I average around 50 wh/mi and around 40 miles I’m ready for a charge break. I built my board for fast charging so on a trip I can go from nearly empty to full in around an hour and a half charging at 30a.
I’ll reinforce what others have said about the duality trucks. More than the cost they are the safer option, extremely predictable and precise trucks that won’t randomly wobble out on you. Also extremely fun to carve on.
I used the Bak 45D cells. They were on sale when I was building so went that route.
This is far easier said than done.
Butyl rope seems to be the most effective way to seal enclosure against the deck, but then future access to internals becomes messy.
STREET BEAST | 16S10P BAK 45D | Dual 56118 650kv motors | 79/12 Gearing | 240mm Tito Duality Trucks | Tomiboi Odachi V2 | MakerX 2G300
Off road as in gravel road or trails?
Gravel roads. For trails, this thing will be way too heavy.
They aren’t great. There are so much better cells on the market now. Take a look at nkon.nl chances are you’ll be buying your cells from there.
I recommend tabless cells they aren’t really more expensive but perform so much better. Nkon has some Tenpower 50XG on the way now which are amazing cells, 60XG as well for a bit more, which would be even better for big battery.
Oh.. i thought Samsung cells are really good. Youre the first person telling me they are trash. Yeah, i will get the cells definitely from NKON. So youre saying Tenpower are better? But how many charge cycles do they survive and so on. Id love to have 6k cells, but i fear they aren’t available in any usefull quantities yet and they are bound to be pretty expensive.
5000mah tabless cells will perform better than Samsung 50s. You also have to be pretty conservative when calculating range. Me and @Pecos had been using cell’s continuous rating as max rating from Mooch’s data sheet and that seems to give us realistic available Ah.
Ive just been looking into different cells and all. Is it a problem if my pack totals out at 125 Amps? Whats the tradeoff?
The samsung 50S can handle about 23 amps continuous from 4.2 to 2.5v, without exceeding 80C, barely.
This is a single cell in free air, not a pack of cells wrapped in Fishpaper and kapton tape in an airtight enclosure.
The Tenpower 50XG can handle 40 amps continuous from 4.2 to 2.5v and not exceed 75C.
If one were to put a side by side discharge comparison of a samsung 50S against a tenpower 50XG under 20 amps of load, The Tenpower would maintain much higher voltage for most of the discharge, and stay far cooler doing so.
The Reliance RS50 performs very similarly to the Tenpower 50XG and has exceptional cycle life.
Samsung 50S cycle life is not impressive.
The new 6 amp hour power cells are indeed pricey, and some of the cycle life data coming in, is less than stellar, but this data is pay to play, So I am not giving it away.
recommend joining these patreon:
https://www.patreon.com/c/batterymooch/posts
https://www.patreon.com/c/Pajda704/posts
https://www.patreon.com/cw/DIY500AMP
Id like to use these cells: INR21700-M58T 5570mAh - 12.5A as they are super cheap on NKON right now and even though they are reclaimed, i would just use them till they break and later on replace them with a solid 6Ah solution. Any thoughts? The 15s10p pack would total at a 125A only though, is that still in an acceptable ballpark?
I’d just build the final pack first. It’s a lot of work building a 15s10p. Not worth doing it twice. In my opinion those cells aren’t good for esk8, if you take energy cells and draw more than a few amps per cell, you’ll actually get roughly the same range than if you had a high power cell. If you go for the high power cell the board will perform much more consistently, be able to peak more power, and at 10p you will feel virtually no battery sag.
Also I had bad experiences with a batch of reclaimed cells from nkon in the past, your mileage may vary.
