Haha I’ve put in weeks if not months to get this f*cking job done ![]()
Even then I wouldn’t trust it as much as a top mount box. Personally I think it’s for puddles and incase you get caught in the rain. I wouldn’t ride bottom mount enclosure willingly in the rain.
Thanks for all the infos @SternWake
Ill go with the Tenpower 50XG, thanks to your recommendations. It also sits in the “still affordable” zone and is available at NKON, unlike the Reliance RS50, which would have been my second choice.
@Dinnye Yeah, ive seen the amount of work that goes into building a pack. I wouldnt mind doing it twice, but you have a point. Better get it right the first time.
@Tilt I know it wont be a job done in a day. Just need the right tools and some patience to be done.
@MichaelWA The main thing that puts me off from the top mount box is that esk8 is a legal gray area in Austria, technically illegal and i dont want to stand out like a coloured dog when riding. This deck will be used in the city mostly and even though i was never stopped by the police in vienna (fingers crossed) because they are really lenient when it comes to esk8, i dont want to draw too much attention as i dont want to hurt the community.
What ya gonna do for a welder?
Does any of the esk8 guys had any bad incidents with police? Esk8 are also in a gray zone here in the US since they’re not specifically listed in the law but most places don’t care as long as you don’t cause any troubles.
If you’re worry about police actually pulling you over and seizing it. I’d either get a PEV within the law or build a smaller/more lowkey esk8. A 15s10p esk8 will stand out no matter what and it’d SUCKED if you have it taken away.
@glyphiks i just weld them together with @Tilt he said he has a welder i can use.
I know it wont be a stealth build, but still way more stealthy then a mountainboard with a top enclosure. But naw, like i said, the Police in Vienna are super lenient when it comes to esk8, so the community is doing fine. But i dont want to tempt it.
Malectrics
I came across a public post from Pajda, regarding the Samsung 50S2 cycle life.
You got to be a ES forum member to see the full resolution charts
The Samsung 50S2 is an improvement over the 50S in cycle life, but neither do very well.
At a low and slow charge/discharge rate it does worse than at higher rates, surprisingly.
I theorize this is because at higher rates the 2.5v cutoff is still leaving some juice on teh table, but at lower rates discharging to 2.5v is sucking it dry.
Low and slow it takes a nose dive at 390 cycles, dropping from 4200 mah to 3000 mah by cycle 450.
On the latest and greatest 21700 , money is no object cell front, The LinkData 70P is currently available through an Alibaba vendor. They are claiming 40 amps continuous with no temp cut, 60 amps continuous with 80C temp cut.
Their 65P is an impressive cell too.
