So, im a little freaked out abt MTBs but you are right. It completely depends on the finished build and maybe going with a Shogun instead of the Odachi is the more sensible choice in the end.
I reckon youāll find the odachi to bebigger than a trampaā¦
I have a shorter drop-deck, the Liquid sword, that Iāll be releasing later this week. Although, I kind of like the MTB direction. I think it will end up working better for you in the long run. Especially, if you intend to do any off-roading.
Ill stick to the Odachi. Its just the perfect deck. If i ever will want to switch, im very sure that i can find a buyer for it in Europe.
I also just sent a DM to @Dinnye for the geardrive and trucks. My next step will be to start looking at motors, but im pretty sure ill go with the radium 6485 with 172kv. I just hope they fit without having to saw off the shaft.
Still unsure about the battery size but i think ill go with 14s11p. ESC will be the VESC Duet 100V and ill also take their BMS.
Remote will be a flipsky v4.
Still undecided about the hubs and tires. I like the newbee pentagram, but im still looking at that front.
I also want to have fixed lights that are powered by the boards battery. Need to research there as well.
Id love to update my original post but cant find the edit button anywhere. I messaged @longhairedboy about it, but he didnt respond yet.
Unfortunately the BN channel trucks only fit mountainboard decks, you need around 30 degree angled tips on the deck for the channel trucks to work.
Good choice.
VESC is a good choice, Iād do higher voltage battery however, just because thereās no good reason why not to. 18-20S ideally, itās a better fit on 100v hardware. For 18-20S choose around 140kv for motors.
Make sure you get the vx4 pro version if you go with flipsky. GB remote is a good option to also consider.
Everyone here, their friends and their mums all tell me to go with a MTB deck. Now even @Tilt tells me to go with a Mountainboard. Well fuck it, then ill go with an MTB instead of the Odachi. I want an AT Carver. With 6485s i need 300 trucks which would make the drop deck turn like a truck and impossible to carve with anyways. So .. well.. MTB it is then.
Personally I have really really enjoyed my build using one of @tomiboi ās MTB decks and the @Titoxd1000 duality trucks, 300mm hangers still feel plenty agile, when it comes to hanger width I will say in practice Iāve seen @MacKeeper28 run 6485ās on narrower 240mm hangers, you just need to be mindful of the distance between the motor cans and the aluminum pivot cup at the rear
I run a top box setup (18s5p) which has been really great for daily use, small enough that it doesnāt end up encroaching on foot space with how roomy the deck is and having the battery up top keeps it out of harm so I can do silly things like drop my ride height in line with my axles with 6ā tires and still have something thatās fun to carve around and drop off curbs.
In terms of the electronics I think 18s/20s with 173kv motors is a good pairing, even on hot days and under serious punishment I havenāt seen motors giving out and it seems like the efficiency is pretty good
If you can get a set of Duality, highly recommend. I had a 300mm Duality set + Haero Bro deck and that had plenty of turns. Pretty sure Duality + any MTB deck will give you lotta agility.
How much flex are you hoping to have with the deck. This helps determine the enclosure. If you want a stiff/semi-stiff deck, you can do whatever enclosure you like, top or bottom mounted. If you want super-flexy, go with a top mounted enclosure. If you want somewhere in the middle, Iām working on segmented enclosures right now for the shogun. A segmented enclosure would work well for the middle ground, but you lose capacity with a segmented enclosure.
Ill go with something in the middle. How long do you think until you have the segmented enclosure ready?
About a month. Do you think youāll do a double stack? Iāll do that one first.
Yes, definitely double stack. Whats the max Battery size for that enclosure then?
15s10p or 30s5p.
Im thinking about putting a meshtastic LoRa module with GPS inside the deck, so i have fallback communication if there is no cell reception and also as a way to track the board if it should be somewhere i am not.
I guess i found the BMS i will use for this build:
never mind that. I forgot to check the measurements of the BMS .. this thing is absolutetly massive.
Most DIY esk8 use a much smaller bms wired only for charging.
Indeed.
Strongly suggest the JBD smart bms. They come in configurable voltage options, great compact size and considering most diy builders only set them up for charging, you can spend a bit extra to get a higher current rated option for huge charge currents.
You can get a lot of turn and agility from matrix 3 at trucks with singularity bushing setup from riptide. Similar if slightly less from dualities - they have a bit more finish and feel slightly less linear in the lean but are absolutely beautiful. I have both and think they are very agile in comparison to rkp type trucks - but they donāt do rake. I like them at a huge split low angle - loke 35/25or 30/20 and i can do U-turns in 2 parking spaces or 3point in a single spot. If you want agile and fun - traditional at trucks are poop but these are exceptions
I was mainly looking for a BMS thats waterproof out of the box. I am looking to build something that i can theoretically ride in the rain as well if i have to.
@Pecos thanks, i will for now stick with the BM Channel trucks im buying from @Dinnye but will keep these in mind for later consideration. They look p much like what id want.
