tell your friends
If you didn’t already have a title, I would give you “Using Super Trooper Enhance Mode.” Great catch.
thanks
Im always down for a new one.
I only have this one because I angered the Manner
Hence the reason I didn’t change it. One day, we will rise as one and defeat @mmaner . Until then, he’s esk8 Ken McElroy.
Noooooo, you didnt anger me, you challenged me .
I must say, that was a pretty great title. I have now changed it to “Using Super Trooper Enhance Mode” so that no one will assume I am angry. I AM NOT ANGRY!!!
I had to google that, my feelings are hurt .
Manner, the Manliest of Man
Thanks guys, I love it
New problem. Motors are spinning in opposite direction
Swap any 2 of the 3 phase motor wires and it will swap rotation
Okay so that worked but now one of the motors is having some hesitation. Will only go at full throttle
did you rerun the motor setup?
No i did not
you will need to,
The can bus is used to do any communication between the two escs.
if it was backwards during the flash, then the slave esc is effectively flashed (factory specs)
In this factory state the esc has no idea what sort of motor is attached , so it will not be able to correctly control the second motor
Its spinning the wrong way in the set up. Like during motor detection step
its fine, there should be a button to reverse the direction,
or swapping the direction on the phase wires like Justin meantions.
Pictures of your software help here,.
For context:
the motor setup works either way, does not matter which way the motor spins during detection.
After detection the mH and mOhm values should be roughly the same (within 2 of each other)
Once thats good, and teh motor still spins the wwrong way (either one) then just hit the “reverse motor direction” box the the relevant motor
GOT IT. IT WORKS. YESSSSS
wear a helmet
Will post photos later. Much love fellas
