send a picture of how you wired it up
Yes. All lights match
looks like its wired up alright.
how do you mean motors spin individually?
this is a big nono insulate those wires son
So after I’ve followed the steps on how to set up the ESC using the Ackmaniac tool. Step by step. I can only get one motor to spin. But what I did to make sure the other motor even works was set it up as a single ESC. I mentioned that so you guys know that both motors actually work.
have you set it up for dual and then run motor detection?
Do I need to insulate the parts if the bullet connector too?
absofuckintootly
no exposed metal anywhere is best
I just did whatever was included in the “how to” with Ackmaniac tool
Yes, for sure.
Are you using the wizard and setting up as slave/master?
Yup! Did it exactly how the guide said.
And both motors rotate freely by hand?
Yes they do
Is it the right motor not spinning?
Depends which one I set up as the master
have you tried giving the spinning motor spme resistance with your hand when its spinning? i might be wrong but if there is any sort of software differential going on then only one motor will spin until a load is applied
This has to be a can issue then.
electrical tape does NOT count haha. good for now but that will falll right off after a few miles
