You are not alone. My lipos are in a cardboard box too. ^^
Hi Iām Nick and my first build is a pile of money slowly catching on fire. Is the coffee and donuts over there for everyone orrrr⦠?
Iām trying to fix the focing blown DRV.
Parts and materials on order and will be here next week.
I have got these two drv error 4.12 VESCs to try fixing before I take a crack at the focbox.
and before I take a crack at any of them I have wasted $30 getting a FOCishy
Need to find something creative to do with it besides taking chips off and maybe putting it back on.
Ideas anyone? I was thinking about casting it onto epoxy and making an X thing out of it.
Do you have the spare DRVās on hand to even do the replacement? Turns out if you look longer than 1 micro second you see the second screenshotā¦
I really should have got like 5-6 DRVs but I like to live life on the edge I guess.
Iām trying to save to buy TB 6.64 ESCs this month, canāt stop myself from wasting money on other crap tho.
If you wanted a test PCB i have one or two CheapFOCer V1 boards laying around that Im not planning on using, but if you dont have any flux or solder its not going to do you much good.
This is what I got the FishyFOC for, its as good of practice as I could ask for really.
Then the DRV error but working 4.12 VESCs are the warmup and the broken FOCBOX is the final boss.
Keep us posted. I have a broken DRV, too. Iād love to learn how it goes for you, so I can then do the same mistakes.
Haha looks a lot like what I made before this build with my hobbyking SK8 conversion kit thing. Except mine was a lot smaller only having two 6S 4Ah lipos that got about 6 mile range. I used the box my flipsky VX1 came in as it all fit quite nicely. Got a couple good rides out of that I think.
I got my drowned Focbox today (and the DRVs but the solder stuff is delayed) and took it over to the hot air station to blast heat on it to see what happened. (nothing due in part to the corrosion and rust layer over all the pins)
Realizing a lot of things, a minor one being I need one of those flux pens and some tweezers. A major one being that I am thinking I should not have attempted to DRV swap anything, much less 3 VESCs. A lot of money in on it and that pushes me to keep trying, so I guess spend more.
Iām going to lower my confidence level down to below 30%
you need ceramic tweezers, liquid flux, solder wick, chip-qwik a PCB vice and a microscope would be helpful⦠HOLD THE PCB as level as possibleā¦
remember you aint fucked it up until you power it on⦠do continuity check on every pin on the DRV⦠and every pin on that your hot air loosens the componentā¦
have you watched a video or two atleast?
EDIT:
everyone has a piece of crap electronic device to practice onā¦
@Fosterqc
Yep I watched most of the video of vedderās hand and @Fungineers video. Also a couple videos on general SMD rework.
I have all that except the tweezers and liquid flux/flux pen. I have some PCBs to practice with as well.
This will be highly difficult but I am up for the challenge, although I am wishing I had just sent it to a pro.
you can do itā¦
BTW⦠itās easier for me to use chip-qwik to take the bad one off⦠and solder paste to place itā¦
remember:
it aināt fucked until you power it up and checkā¦checkā¦check
Flux is your friend! use too much!
i donāt know if you care⦠but this is where I got my inspiration to take apart electronics that I had NO idea how they worked (electronically)
It should be time stamped to the correct time linkā¦
Sounds like you might as well go all in now and become the next drv-wizard.
Bluetooth module added switched to ACK. Actually āattachedā the wires to the deck no more droopyloops.
Oh forgot to add:
I TAPED THE PHASE WIRES SO THEY CANāT SHORT
First? tentative ride. Need to use a GPS tracker to verify the distance traveled and try to not do any air spin checks to see that itās working so I donāt mess up the readings on range and max speed.
Also thinking I should raise the motor current to 80A from 60A. Batt amps set to 50A currently.
I agree that AWD/FWD is more stable than RWD.
so are you gonna try to protect those precious focboxes???
