Finding the ideal trucks
On my newest build I’m having difficulty selecting trucks. Its a flux deck and
i mainly do high speed street riding. Currently I’m considering:
MBS Matrix II / III or something from
Trampa ATB spring trucks
ONSRA TKP CNC truck kit
Anything else I should consider or insight on the choices mentioned above? Thanks.
Bioboards have channel trucks releasing soon.
Personally I would consider Newbee RTKP trucks and reverse the rear baseplate for stability. Or there’s always Moon’s Luna trucks, which are really great on Flux builds.
On a deck with angled tips like the flux that’s going to be insanely turney, to the point that you can’t even go straight lol. Also their axle length is really small, not meant for the usual AT wheels people here use.
I really liked my 3d servisas set when I had a flux deck, with radium bushing adapters and riptide blocks its really nice.
Your riding style sounds like it’s similar to mine and I had no problem getting those 3ds trucks past 50mph with the right setup.
My channel trucks are coming out soon.
Already in machining.
Took some time to learn the machine’s control but I am happy with the results.
310mm hanger width, 65mm wide axles (custom lengths available)
21mm hanger profile; 20mm square mounting square
Riptide Bushings
0 deg or 5deg angled baseplates
Wait you can do that? :drooling_face:
Those look pretty sick. You should sell me an early set for testing purposes :wink:
Those look gorgeous. I need to get a higher paying job so I can afford all this cool shit.
yep, all you need is these things and any matrix 2style truck will work with riptide bushings. Its such a huge upgrade, the quality of the riptide bushings will completely change a board compared to the cheap mbs bushings
Nice. I was sure they only work in M2 and especially since 3ds seems like trampa bushing geometry.
I don’t even bother with trucks that don’t accept riptide urethane anymore :grin:
Lacroix Hypertruck is also an option.
I’m really liking PKPs paired with my flux deck, had to change around the bushings a bit and mess with them but I can carve super hard around 15 mph, and still able to hit about 40 without feeling unstable. Turning circle is decent too, I can 360 on a two lane road pretty easily.
@Boardnamics 10mm axles possible as well?
Definitely, as well as custom hanger lengths
Thanks for the help everyone, you guys really helped me make a selection.
Could you explain why you went with 0 and 5 deg for your options?
I feel like 5 deg could have been achieved with angled risers, and people would go crazy if you had a ~35deg version for flat decks.
Could, but even 5 degrees bends bolts a whole lot. And on flat decks channel trucks really raise the ride height…
I was not saying it was a good idea I was saying people would buy it
Which way did you go and what has your feedback been w/ that decision I wonder;)
I’m also tryna achieve higher speed stability w/ my Lacroix w/ Hypertrucks if possible. 45+mph speed stability.
With the Lacroix angled deck tips are channel trucks the best to accomplish this? Or should I consider another truck in this day and age of 2024?
What is the best degree for rear and front for angled wedge risers?
Thanks!
