Coming soon new version ECO gear drive
What are the changes? @3DServisas
Will work with other hangers , hubs and improved gear drive
Looks great! nice drive for saving some weight
What’s the gear ratio?
Gear ratio 1/4,2 or 1/3,5
Nice that the 1:4.2 is also an option!
Any idea when these will be available, I was depressed when I went to buy the old ones and they were out of stock - spotting this totally made my day!
Once the spring starts, the ECO gear drives will appear in the store
So V2 no longer works with bergmeisters?
The compatibility will be gone for now.
Very curious nut
Bust a nut getting it to you, gratitudes
What bolts did you guys loctite? I am on the edge of just removing every bolt one by one to loctite everything, but I thought some were already loctited when preassembled so not sure.
Is that smoke from the V ring?!
All screws should be already pre-loctited. You should only loctite the screws you add(motor screws) and keyway, motor shaft.
I think it is written in the store.
