Hello, I have been a long time lurker here and finally joined in hope of some recommendations.
I have an Evolve GTX with the 10s40 30q upgrade and I am having some problems. I am only getting about 13 miles of range, but as far as I can remember that is the range I have always gotten. I ordered the cells from liion, but am starting to wonder if they were counterfeit.
To answer some questions you might have, yes I have looked in the battery diagnostics section and everything looks normal.
The main question I have is if you can hook up some external batteries and run them in parallel like you can with Onewheels. The batteries that I have in mind are some of those 36v hoverboard batteries or some lipos. Has this been successfully done before? I am running all stock electronics if it matters.
At this point I know it is possible, I just dont know at what point to splice the parallel wires. Between the battery and BMS, or between the BMS and ESC. I have a feeling that between the BMS and ESC would be best. There is just nothing out there besides this youtube video ( https://youtu.be/zz7m612x4aw ). In the comments all he says it "solder it onto the motherboard, and last time I checked I was not riding around on a computer.
Yeah, I think that’s “real world” range for that config. Was getting the same range from my battery on my diy board with ATs. I’m upgrading to 10s6p hoping to get bit more range.
Only other help I could offer would be to charge completely and let balance, then ride till you start to experience sag, then check cells then. Im guessing that is when a suspect wimpy p group would be most apparent. Maybe group 6 is suspect.
