I don’t have the files unfortunately. I can see if I can get it after Chinese New year since everyone is on holiday now
@ Esk8supply Is there an option for motor covers or something like that and is there an adapter for cloud wheel core or an ABEC adapter fits?
Hi can you help.
What was your experience with this set up? What size wheel is it and what kv motors are the DD? Lastly how many amps did you put through each motor? Thanks in advance.
With the 145mm haggy’s it was kinda poor on the braking power. I think those were the lower kv ones. I think 58 I don’t remember. I switched to front wheel drive and it kinda worked better but they still got really hot. I ran 45amps I think through them at 12S.
I switched over to the TB110’s and it was much better. However I still kept the FWD as the braking power was still bad. I ended up getting rid of them after a bit and went back to belt drive.
Oh man. Not good! 107mm abecs on 58kv DD work fine for me, but I want to run small 5-6 inch pneumatics to go over crappy roads. Thanks for sharing.
