ESK8 Forum Universal Heatsink | Supports Most Major ESCs
Are the mounting holes in the center on the 60d?
Veritable gold.
Don’t sweat it, most humans don’t get @kook’s sense of humour.
haha for sure.
seriously @surfnacho can’t you find the humor here?
looks centeredish to me, a bit offset. I will try to fix. The unity is very slightly offset also, but because it is smaller it fits just fine
That there needs a calliper.
This is not my stormcore, I can ask skyart.
Just saying, great products don’t just back themselves into greatness. Those holes are definitely not centered.
lol, that is why I added the ish. I should have taken that into account
@malJohann
I have asked for that dimension. But yes it will be offset a bit.
Are these the stormcore mounting holes in the circle? Because I was wondering if it was centered in the way of my arrows… I guess we just accidentally found out it wasn’t centered the other way too
InkedInked95207ccaa48ab186ea58b9d7a89202f005db8499_2_690x493_LI
right, so I should have accounted for that. The holes on the heatsink are centered, while the stormcore has offset holes. so the esc will sit a bit offset. I will fix that for next time
edit: I am working to fix this, or at least make it less of an issue
Does it still fit within the footprint though?
ok, I have a bit of time. I need dimensions, I can fix
I think I may switch to the two mounting holes on the edge to keep it totally centered.
What is anticounterbore?
haha, wasn’t really sure what to call it. I have a counterbore on the opposite side so the head can be concealed. Maybe just a “counter bore” but on opposite side idk. I changed it to avoid confusion
@BillGordon @mmaner can one of you guys split this, and add to the dev thread. Probs shouldn’t have opened this one until manufacturing begins.
@JoeyZ5 @malJohann
The great @sofu was able to test dual storm core. Does this offset seem fine to you guys? I’d rather not change it because it is the same holes as unity
That’s fine for me.
