If you were going to start skating anew, with little to no experience (and the associated lack of co-ordination ), what would you wish someone would tell you?
I’m looking to build a ‘curriculum’ of sorts for extremely new skaters, a kind of checklist of goals to ease into confidently cruising up hills and over the rainbow (maybe not actually over the rainbow). Any input is appreciated!
if someone would have told me to put your weight at the front for acceleration and for braking put weight on the back foot it would have saved around twice falling off
also at first accelerate slowly and dont lean as far as you can to turn
can i ask where i london are you as i am in london also
For my clients, I will be looking at getting a supply of knee / elbow pads, full face lids, wrist protection, and gloves.
Autism being a sensory processing disorder, I would like to look at things like armoured trousers, as that would be less stressful for them, but the cost seems to be a killer with that kind of thing.
@ratheruseful You should properly make this thread [SERIOUS] to prevent @Halbj613 making this offtopic
anywayyy, learn to jump to get over curbs everywhere. Also, learn to fall without damaging yourself, and if no bindings do not try and run it off at 20-25mph or more.
Edit: The mark where you can run off at is different for all people and also depends on age, obviously.
Think of it as snowboarding or skiing if you’ve been.
Keep the weight up front. Use your shoulders and hips to turn, not your ankles. Get comfortable leaning further off the board, it will be awkward at first. Start with loose bushings. Use your read foot almost like a boat rudder, dragging behind you and swinging out on turns.
Example (normal stance, left turn):
crouch lower
more weight on front heel
turn shoulders to the left, hips follow
lean out off the board
swing your right foot out gently to maintain a smooth turn
bring your body back in while the board returns underneath you
Don’t try and stop your fall with your hands or you’ll end up with broken wrists
Best way to get “good” at falling is to fall purposely, but in a controlled environment where you KNOW nothing can go wrong, do this at YOUR OWN RISK, this is just how i got comfortable with bailing
Rock and roll it out, and when i mean roll, i mean roll like. You don’t wanna land on hard parts of your body, land on the soft stuff since they’ll only mostly only get scratches or get bruised
Wear protection
This is from own experiences and how i got comfortable with bailing so take this with a grain of salt since there might be better ways to get out of a shitty situation without getting fucked up. So also do your own research, but that’s up to you. I do not want to be held accountable for shit that happens for other people on esk8’s. Hope you understand.
