Thanks for this mate, was looking for a good free video editing tool myself this weekend.
Let me know how you find it! I managed to du more in one day with it than in weeks with Adobe Première, way easier to handle and the video quality is sleek. Smooth and lot of settings,I have only touched the tip of the iceberg so far haha
YUP DaVinci is da shitz!!!
I have the exact same cable, I was looking for extras and found this. This has worked for me and should be fine. https://www.ebay.com/itm/173996705347
Just get the plug obviously unless you want extra cables. I use them on basically all my micro usb stuff.
You are the best
what i suppose to be a magnet coming loose suddenly made my board sound more like an f1 car compared to silent unity foc…
i dont want to fix it
I had a Maytech “sealed” 6374 that sounded like that when the bell got a tiny bit bent. Sounded like F1 car. The “bell” turned into an actual literal bell.
tbh i have no idea yet whats really causing it… i had an old belt snap under heavy acceleration and had to run it off… board ran into a flexible fence with the front left wheel, no drastic impact really…
but since then that badass sound is accompanying me
faaaaaaaaaaaaaaaak it’s hot… we went from winter here in ca. straight to summer…
i moaned when it was cold… i’ll moan again when it’s hot…
it’s what i do…
90ish with 80ish humidity here the last two weeks. Now go hang your head in shame in the whining corner.
Ya lucky bastards… we haven’t even broken room temp in the great white north lol.
It is currently 4C aka 39 freedom temperatures…
using a battery pack that can output only 10A and pulling 20 from it untill it blew up
it’s all gone, i’m making a real battery pack now
come on now… give us some back story… some pix… regale us with your tale of woe, sorrow, and disrespect for the principles of physics… we’ve all done st00pid shit… and we all delight on the misery of others…
the only shame from failure is failing to learn!
spill your guts!
i used cheap fake capacity 10000mah lipo cells, those bag types.I put none in parallel so it could only output 10A but i didn’t set the max amps in the vesc tool so it pulled 20A. Sometimes my board would not work after a few kilometers and i would have to turn it off and on again. i got no pics
those are some fuking repugnant specs… a lipo capable of only 10amps, are you serious?? I’ve never experienced a 1C 10A lipo battery
10000ma x XC = 10A… C=10A/10000mah= 1C
are you sure you don’t have something misfucked or a HUGE bottleneck in your set-up…
the capacity was fake
