Haha I believe @Andy87 did this once, with much spicier results
What bms was it? I’ve reverse polaritied a couple of unfused LLT charge ports before and the bms/batteries were fine but chargers were toasted
it’s the 20s daly bms, non-smart version, separated ports, bypassed discharge
Does charging still work? Worst case the BMS is gone, no big deal imo.
Also using the same connector for charging and turning the board on is a reaaaalllyyy not good idea.
He likes to live life on the edge
Yeah I replaced the connector and charging is normal.
Is it safe to plug in a 20s charger without an antispark? I’ll totally change it to an XT60 if so.
Whait are you using an XT90 for both your charge port and loopkey? Why?
XT60 isn’t available as an antispark connector.
Yes I know, that’s why I didn’t use one for my charge port and went with the spicy, confusing route instead
I have a clear disclaimer posted here, you’re not allowed to be surprised
“Okay, so here’s the kitchen in your new house. That switch turns on the light. Don’t flick the switch next to it, it starts a huge fire on the stove.”
That analogy is bunk, stoves are supposed to have fire on them
Not huge ones
not with that attitude
Not modern stoves
Why is there a “Blowout front right tire” button on the dashboard?
Because putting it on the console is less convenient
