Welp I’m not exactly sure what you’re referring to, but if you’re speaking about the status of my opinion on these wheels…
Well lets just say they aren’t staying on my board for the time being. They’ve been a pita since I got them. I’ll explain soon, been doing other things and haven’t wanted to write my whole update yet.
I’m going to write it soon, but TLDR that since the provided pulleys make the whole wheel-pulley setup too wide for standard extended axles (Boardnamics fixed), you have to use extra long shoulder bolts. I’ve hard terrible experiences using the longer shoulder bolts already, and this reinforced how much better fixed axles are.
If I can figure out a design for a 3D printed pulley to use with these wheels I may revisit them. For now (when I get to it this week), I’ll write up what I think and move on
In interesting of keeping this going, I’ve designed a pulley to work with these wheels in union with the metal pulley spoke adapter.
V1 is looking pretty great. Got some minor dimensional adjustments to do to make it fit better but at initial look, the 37mm bearing to bearing spacing on my design is easily used on extended axle trucks whereas the 50mm of their pulley is not.
They remind me a lot of a Trampa gummy. Me personally, I prefer thane if I’m going for a bigger airless wheel. I’m just waiting for Dexter @torqueboards to stop quarantining his secret 130mm wheels he produced.
Lol everyone wants them but I’m not convinced that they would be much lighter than airless wheels like these. I swore by my TB110’s until I rode pnuematic and then got spoiled. Only downside of the pneumatic is the range cut
If you’re asking about the one I printed, I designed it last night and refined it a bit today. I can weigh it for you, I printed mine in PLA+
We will see how many miles it lasts for, hard to say without testing. I’d like to get some Nylon and print it in that too
I’ve finished my design revision of the pulleys, they’re rev 3 now with the final changes. I think they look great and am excited to test them out. With these pulleys and standard width bearings you can now use the Eovan wheels on standard extended axle (50mm) trucks with some room to spare.
Unfortunately I neglected for some reason to weigh the pulleys before putting them on my board. I will weigh them after I do a post-ride inspection. From guessing, I would say that they are less than 1/3 of the weight of the original pulleys.
Rode 10 miles on these boys today. I have to say I am pretty impressed and they are quite comfortable to ride. The pulleys worked perfectly and after the ride I couldn’t see any obvious wear on them.
I fully expect wear after 50-75 miles but it will take a little while to get there considering how early it gets dark in the winter.
Considering you mention that, I am curious to see how well the wheels themselves wear. It seems like they will wear pretty quickly. Hard braking leaves marks even if they wheels don’t skid
Is there any interest in me making a fully 3D printed pulley for these?
In my current pulley design, it utilizes the metal adapter from the original pulleys, which I believe would make them last an extremely long time with no breakage.
If there is interest I can design and offer a fully 3D printed version after testing it. I will be testing these pulleys for a while to see how many miles I can put on them before wear starts appearing on the PLA+. Additionally, I will be obtaining some Nylon filament to see how those last as well. The Nylon would theoretically hold up a lot better to hotter environments and would theoretically last a bit longer due to its higher wear capabilities.
I am unsure how much the spoke design varies between different versions of these wheels. However, if you do have the metal default pulleys that these wheels come with, it’s not that hard to take off the metal spoke adapter to use with pulleys like the ones I’ve designed.
Went for another cruise today, about 11 miles. The wheels performed well on varying surfaces from asphalt to grass and gravel. I’ve been impressed so far with their performance. The pulleys seem to be holding up just fine.
