I was following the original marlin guide that has pre-configured creality Cr10s files. Then you will need to define some lines in the code to activate bltouch, set the offset from the nozzle ecc…I am just sure It won’t work the first time, as usually. I will take me some tries
Do you advice TH3d firmware over the original Marlin? I do not understand why so many possibilities. It’s confusing when you want to track back how to do it.
I already bought the one from trianglelab, didn’t know one was available from Creality. I wil ltry first nad in case ask you guys for help. What is not clear to me is if I need something to flash the firmware or simply by connecting to the printer with USB and then using S3D or Cura to send the firmware. Some tutotial uses a ttl connection to do it.
TH3d has everything preconfigured for said printers. Makes it super easy. Select printer, select auto leveling device, select probe offset and set mesh point amounts.
Honestly I’m probably going to eventually switch over to marlin anyway but it makes it about a 10x easier if it’s your first time.
No main reason but I want to tweak my firmware a little more without having to dig through TH3d firmware.
Also I haven’t been able to get some gcode commands working that are listed in marlin and wanted to see if that was the issue or if something else is going on.
One thing I don’t see as option in the th3d unified firmware is the possibility to change the grid for the auto leveling. Like 3x3 or 4x4. I only see it for the ezabl they sell. I hope it’s 3x3 otherwise takes forever
