I made a little cardboard test enclosure to make sure the electronics will fit. While figuring this out I had a few problems, which hopefully you peeps can help me out with. What see-through material should be used to cover the the battery indicator, and where can I get it? Also, what is the best way of waterproofing the ports? I was thinking of hot glue and a rubber cover, but are there other better ways to waterproof the ports? Thanks!
The fewer holes the better.
You don’t NEED a battery gauge. @b264 has a good solution to the battery gauge, and @mmaner made a similar 3d printed option.
You might be right. I haven’t tried with silicone, but I always do that with hot glue. Hot glue just forgets that it’s glue the moment you spray some isopropyl alcohol IPA.
I recommend externally mounting anything that requires a hole in the enclouser, IE the charge port and the On Off/Loopkey. Then use bluetooth or a charge port voltage checker.
I kinda wanna get another charge port/loopkey riser from ya. The abs cement fixed the last one pretty good.
I just want one in my parts bin for potential builds and another to give away in my secret Santa box.
