be that as it may, the problems Win experienced persist to this day and are based on the motor locknut that does not adequately secure and center the axle to the motor can.
Yes, I think it was the OG 72kv, though.
No. 100% sure not OG. Because it had the rough surface finish. Not smooth can like ours.
I āthinkā the rough surface was OG 72kv, the smooth can with locking screws were OG 58kvā¦
And speaking of the motor can locking screws, Kenna and Nathan told me directly they were abandoned because they did not adequately lock the end-cap to the can⦠so they were eliminated.
Now were back full circle and the end-caps are coming loose because no locking screws and no thread compound on the can and end-cap⦠go figureā¦
Correct. Pretty sure Winfly got the ones that were supposed to come to me. But to be fair, I would send them to him first, too.
Aww thats cute
Nope. I have OG 72 and 58. Both smooth can. I am using the 58 and 72 are just sitting (hooked them up to ESC though)
@Goldrabe also has the 75kV smooth can OG drives.
Popping corks everywhere will sound like Beirut in the 80ās
Slapdown from the Mishra man! I stand corrected.
Iām currently running my 58kv without any unscrewing of the cans but hopefully this isnāt one of those ājust a matter of timeā thing.
Current setup is 12S with 6" pneumies at 60 psi. ESC is programmed with 60A, -60, 20A, -4A, Brake with No Reverse.
I canāt tell if itās because of the pneumies but top speed feels really solid. Could easily go faster without wobbles. Not exactly sure what my top speed is but Iād place it around the 30mph range seeing Iām about 160 lbs.
The mi/wh isnāt great; definitely chews through more battery on the same route than with thane however this is expected. I do plan on getting the tires pumped to 70psi to see if itāll improve efficiency without sacrificing ride quality too much.
Motors donāt accelerate as hard as belts do. This is also expected. Riding uphill through a parking garage didnāt have the torque twitchiness that belts do but definitely had enough torque and power to haul me up from a standstill. Riding up and down the garage (6 floors) only made the motors slightly warm to the touch.
Sorry for not having any specific numbers. The ESC Iām using doesnāt allow for external connections to things like BT modules or DaVega. Iām currently testing it out but once thatās done, Iāll switch over to something that can pull data and report back.
I wonder if the unscrewing of the cans has something to do with vibrations loosening the cans and maybe thatās why Iāve yet to experience the unscrewing because the pneumies are muting all the vibrations.
Iāll know more in the summer when I can ride them daily. We shall see how mine hold up
Hi,
Due to timezone differences I just caught up on the thread, most of you are probably asleep now.
We are deeply sorry for the issues with the can unscrewing and will provide support until they are fixed. (However this only applies to the customers who brought from us, the others who brought from lofty is outside of our control, unfortunately)
I have spoken with the supplier and we are working out a solution for the drives.
this is what we are thinking, adding an extra in the design of the drives. The drives shipped out from this point will be changed.
For the time being, would you be able to do this?
For those who are experiencing issues from the group buy or from our store Please be patient with us. Please DM us wif you have issues with the drive and we will sort through the DMs and get back to you.
Sorry for the inconvenience
Thanks for staying on top of this, Nathan.
What a mess, I canāt believe the supplier is not testing anything.
Iām waiting for my Eovan DD to arrive and sweating while I read all this
Beetween the broken axles and this, Itās getting REALLY scrary
Well shit, I plan to use bergs on these 58KV drives. Hopefully mine dont unravel themselves. I wonāt be able to get mine going for another 2-3 weeks.
Oh, Eovan. Nice guys who promise to send me their stuff to check out, and yet never actually do it.
Whats the point of swapping sides of the drive when you put epoxy in?
Canāt you just swap one of the phase wires so theyāre going in opposite directions? (Both being ātighteningā the can)
yes you can, or reverse mode
