Please show off your precision trucks and the motor mounts you use. Got split angles? Add pics! I’m looking for inspiration to build my own motor mounts to electrify my slalom board. If you have narrow trucks and are belt driven I need you in my dms
Side note : any one running a pair of don’t trip trucks on their esk8?
I’m running @Psychotiller split angle liquid TKPs with dual @Boardnamics mounts… They are a very beefy setup, but buttery and tight carving that’s stable at 20 mph
Then the same build I swapped to surfrodz tkp trucks with an adjustable rear baseplate. I moved it around alot and don’t really remember where I had it last. Ran uurethane and Pneumatic depending on the day.
They are 45/35 split and have a 260mm hangar with standard skate axles, there basically the same as SurfRodz TKP Hex with a longer hangar and different axles
And… there is a difference between forged and or cnc and “precision”
It is not because they are milled out of a block, that they are precision.
You would be surprised if you would bring some of the current “precision” ones to a real CNC guy and ask how precise they really are
