Noob question, I know but it seems to be somewhat hard to find parts, even with a hefty price tag here in EU. Specially when you dont know what exactly are you looking for. All the ready made electrickery components are either not available to EU, or in most cases sold out.
I tryed to get them cheap FOCer made but the part bill is outrageous ATM, just one component (IMU) was 140$.
So to the question: if I get a VESC Flipsky mini FSESC6.7 can I use just “any” IMU board/chip with that? They seem to cost pennies compared to the parts used in them FOCers.
Do I need anything else (controlling the board wise that is) or is that “all-in-one” kinda deal?
Another Q: could you use a different IMU chip in the cheap FOCcer to get the cost down?
I could sell you a used (and I think refurbished) Trampa vesc 6 mk4 which has a built-in IMU for 150€ + shipping
Edit: turns out the IMU is missing, nvm
If it works I might be interested. Soo, would I need something else electrick wise to get a onewheel to work (in theory that is)? Do I need a separate controller board as well?
You’d want something higher than 12s if you’re refurbishing an actual onewheel. For a onewheel hub. The minimum is 15s where your top speed would be ~18 iirc, but its sketchy at that speed. If you’re using a floatwheel hub, which is higher kv, 12s is the minimum where your top speed is around 16, but I’ve nosedived at 16 on my 12s floatwheel.
Nope, building one from scratch. Well, trying to at least… …12s should be high enough, I’ve thought to use locally sourced hud from a Finnish escoot/emoped (what ever you call them…)
Okay, so if it doesnt have a IMU, can I use a separate IMU-board with it?
I’ve been fiddling with drones and all of the flight controller boards have a gyro in them, so it seems a bit… …weird, that implementing one in hoverboard/onewheel VESC seems to be either hard and/or expencive…?
Most probably there’s once again something obvious that I’m just missing
Thanks. Yeah, I’ve allready stumbled on his channel and made notes before finding out that the buyable little focers were just a batch and fungineer aint doing more…
ATM I’m at the brink of ordering a batch of cheap FOCers semi-prebuilt from jlcpcb, and then scavenging bmi’s and stm32’s from broken electronics and handing them to a friend who does phone repairs…
