"Electric Baguette" : SR Carbon Flex 2.0 Limited Orange | 8S4P 30Q Battery | SR Flexible Enclosure | Focbox Unity |TB DirectDrive 75kv | 120mm SR Oranges Foamies
I have no idea what to call this “DIY” project so here is “Electric Baguette”…
About me :
  • French IT engineer, broke my femoral neck in half earlier this year but my previous board was fine and sold it to finance this project.
  • I’m trying to order within the EU to avoid taxes. Unfortunately this is not always possible. Slick Revolution (UK) will be the main provider for the parts used, also there are discounts codes available and free shipping.
Comments about the build :
  • While making this build I had for objective range and a somewhat light longboard. I’m not a heavy guy so this setup should give me at least 20 real kilometers range.
  • Speed will not exceed 25 km/h as it’s the maximum allowed in France since September. I don’t really care about speed I prefer slow cruising anyway. :+1:
  • I did a bit of cardboard prototyping since I won’t finish this build until January at the minimum and wanted to see if everything would fit together. Also that was fun so I will share the result for you guys to laugh at. Everything is pretty much at 1:1 size except for wheels that have the correct diameter but not the good width.
Parts for the build :
Note : this parts list does not include tools and various hardware required like screws, gaskets…
Deck
Battery + Enclosure
Controller enclosure
Motor controller
Motors
Wheels
Lights
Remote
  • Flipsky VX2 Pro
  • Price : 89€
  • Status : received !
    2_25466573-34d4-4b06-8537-891bdb8b6033_250x250
Bonus - Cardboard Baguette :
Cardboard Baguette. Best Build of 2019.
Even with 8s your board will be over the speed limit. @torqueboards seems to be experimenting with lower kv versions, so try getting 50 or 60kv if you can :slight_smile:
50kv with 100mm wheels would be perfect for staying in the limit I think
It’s possible to virtually limit the speed on the Unity right ? But a 50 or 60kv direct drive could be interesting too, thanks for the input !
Yes, but I believe the law requires it to be impossible due to hardware, not software. How will they enforce that, I don’t know, so it probably doesn’t matter. But I recommend the lower kv versions for 120mm wheels anyway :slight_smile:
The law in France is not clear unfortunately, it says that the electric vehicle should not exceed 25km/h and that speed modes on a remote are not a valid speed restriction. I guess that a firmware based limitation and no way to actually remove that limitation when riding should be okay but that’s just my interpretation. Does lower kv help with torque or anything else for bigger wheels ?
you can set the erpm limit on the VESC to not go above a certain value (max speed)
The authorities would literally need to re-program the VESC to “unlock” greater speeds :rofl:
Lower KV will give you more torque and less top speed. In general lower KV is better for bigger wheels.
Thanks that’s perfect.
That would be great for my board, I should look into it.
is there any reason youre choosing this?
Its so so SO much more expensive than it should be…
I agree with you, the flexible battery case is great but the battery itself is priced too high. I’m not able to make those batteries unfortunately, maybe if I get the enclosure I could order a cheaper battery from someone here?
I could get the battery enclosure only for 30 pounds on their website.
I obviously cant give their prices, but youre likely looking at something around 300usd. But that should including shipping, and a BMS… hopefully a loopkey too :slight_smile:
Traveling to the states and bringing back an assembled pack “isnt allowed”, but pricing is likely more competitive in the states… Could be worth to see if they import :man_shrugging:
(to everyone) is an 8s2p more than 99wh? Seems like a great opportunity to split them and make it flight safe
For remotes I would recommend the hoyt skate puck or the flipsky VX1 remote if it is in your price limit or shipping location.
All of it
I understand your point, for exemple a 400£ deck is not cheap. I know I could get something cheaper, but that deck is perfect for me in term of weight, size but also style. @Sn4Pz had a good argument because the battery is something that could be optimized in price. However, you won’t find that exact deck cheaper and that’s the deck I want. The price will delay the time before I ride again, but that’s not the best season anyway. :wink:
The deck is quality, I speak with the guy who makes them frequently. He is a fucking dude and makes some really quality stuff… check out @sololongboards on instagram
Are you sure about this ? I’m pretty sure the law is not effective yet and will be in July 2020.
In French now : La loi existe mais je ne pense pas que le décret d’application correspondant soit déjà promulgué :wink:
You all should have a massive group ride all over Paris or something up until midnight when it goes into effect.
Then a mass reprogramming before moving on lol.
Yes it’s applicable since October to be precise. The July part is about more restrictions like mandatory lights and the likes on the vehicle. But it seems it’s already applicable for speed from what I saw on the gov websites.
FR : Oui il semblerait depuis octobre plus précisement. Je crois que la partie supplémentaire en juillet c’est pour les lumières obligatoires etc. Mais il y a eu le décrit publié au journal officiel le 29 octobre donc ça devrait déjà être le cas.
Links :
Are you sure you want to go 8s? If you are doing carbon fibre deck, you don’t really need their flexible enclosure, which should open you to a lot more options (10s/12s)
I doubt the police can enforce the speed limits anyways haha :rofl:
