How did you do your 15mph calculation earlier? I would be fascinated to know the difference between 46 vs 24 mOhm
how do you calculate motor current at a given duty cycle?
I was using max_battery_amps / duty_cycle but that doesnât factor in winding resistance.
motor_rpm/kv=bemf_v
((bat_v * duty%) - bemf_v) / winding_resistance = motor_current
(bat_v * duty%) * motor_current = wattage_electrical
First attempt. How does it look?
Let me tell you what I have done and I have a question at the end.
All I have done is taken Gamers formulas
- Max power = battery voltage * battery current
- Max motor amps = sqrt(Max power / winding resistance)
- Max torque at motor shaft output = max motor amps * motor torque constant
- motor torque constant = 60 / (2 Ď * Kv)
- Max torque at wheels = gear reduction * max torque at shaft output / wheel radius (IN METERS)
except in step 2 for Max motor amps, I have taken the lowest of:
- Max motor amps = sqrt(Max power / winding resistance) OR
- motor amps in vesc settings OR
- available motor amps based on duty cycle
to get max Torque at wheels. My question at the end is related to this.
Then, I get the acceleration for any given mass by
- acceleration = force/mass
I assume force = max torque at wheels we just calculated. Can you confirm?
I already know the top speed of the boards using motorkv/gearing etc etc, so I am calculating time T to go from N to N+1 mph, starting at 0, using
- Time = ((N+1) -N)/acceleration = 1/acceleration
and plotting the chart.
My question is, do I need to factor in motor IR for the last two options here, where I am calculating the max motor amps available?
Lowest of
Thanks
- Torque = Force * Length of lever arm (which is I think the wheel radius here)
so
- Force = Torque at the wheel / Wheel radius
That is if I am not mistaken.
Keep these all in SI, so use meters for the wheel radius.
you havenât factored the battery current limit. youâll hit that at a certain speed and then youll have a different motor current, which is less than the motor current limit, at every speed. see my previous post.
I have.
batteryamps/dutycycle
I want to know how to factor in IR for the other two options I mentioned above. Any ideas?
how did you calculate the duty cycle?
dutycycle = speed/maxspeed
So, if max speed is 50mph, and current speed is 25mph, duty cycle is .5
I should probably multiply it by 0.95 but I will deal with those minor details later. The IR is throwing me off.
Sorry but thatâs completely wrong, youâll have to do some algebra to rearrange the middle equation:
I saw this earlier. Isnât
motor_rpm = motor voltage x motor kv
so
motor_rpm/kv=bemf_v
is
motor voltage x motor kv/motor kv = bemf_v
so
motor voltage = bemf_v
Is this correct?
3rd paragraph:
I understand it conceptually. How do I get the motor_rpm for this equation?
Itâs the speed the motor is turning at the ground speed considered, factoring the wheel size and gear ratio.
More confusion.Ok, I will think more about this later.
Is the way I have calculated acceleration and speed correct?
first you have to calculate the duty cycle for the desired motor current at the desired speed, then you have to make sure the motor current at the speed youâve calculated hasnât exceeded the battery current limit, because if it has, youâll have to calculated everything again to find out what the motor current is at the battery current limit at that speed.
Reposting because I still feel dumb for not understanding this But the data clearly backs up that bigger â lower resistance
You can have a motor thatâs 50% filled with copper and use thicker wire with the same # of turns and you have the same kv with lower resistance.
I have done this. I calculated the max speed beforehand. Then I am looping from 0 to top speed mph in 1 mph increments and recalculating max motor amps at every n+1 mph. So for a 39mph top speed, it is calculating max wheel torque 39 times.
This code is being run 39 times. I am just not sure about these max motor amps
Start by showing that you can calculate the motor current at a speed when youâre hitting the battery current limit because thatâs harder than calculating the battery current at a particular speed at a particular motor current.
