Same here. They only loosened from my diy hub motor one time after I exaggerated it. They literally melted off when motor temperature exceeded 90 degrees celsius without me noticing that ![]()
Apart from that, no defects at all but i donāt drive them very often either
Give my 2 cents here since Iām regularly working with PU, for PU to bond well to aluminum you need really good surface prep and cleaning (sandblasting and acetone for example) and a primer that will attack the aluminums oxide layer and protect it until casting, Iāve used OP9018 from electrolube with some success but some others might be better for aluminum.
Iāll actually try to cast on top of a regular urethane wheel, not alluminium. Donāt know how well my cast PU will bond to the wheelās PU so thatās why I was thinking about drilling holes on the wheel. That way the cast PU has something to flow into and lock in place. Iāll do some experimenting first to see if they are really needed though.
Hereās a cross section of the mold iām designing. The yellow mesh on the inside is a scan of my 83mm wheels. Iāll tighten it in the mold with a bolt and nuts
Donāt know if any of this will actually work, iām just having some fun.
Little update on my wheel extension experiment.
The 3d printed mold worked great. But even though i put a layer of vaseline on it the wheel just wouldnāt come off so i had to destroy the mold. (Since it canāt be reused iāll redesign the mold so it uses less material and is easier to destroy).
My first try casting the PU looked really good until I got tore apart the mold and the bottom was uncured.
Donāt know what happened here. Maybe on the first mixing batch I got the proportions wrong or mixed poorly but I did exactly the same thing on my second attempt and it came out great!
This 70A PU has a really short working time of 40 seconds. Really hard to work with but it was some of the only PU I could find here in Brazil.
And since I botched the first one and wasted some PU on some tests I donāt think I have enough left for three more wheels, but can cast another one for sure. Then Iāll ride them and see how they feel.
How did these hold up after use? Iād much prefer to cast PU over PU than try to stick it to aluminium.
Saves scraping my current sleeves off, too.
Pretty decent even though the PU I got was not ideal to work with. But it was the only one I could find in my country with a fair price and the hardness I wanted. Definetly try to find some PU that gives you more working time than a few seconds.
The PU to PU bond turned out really strong, I canāt take it apart.
