I just used the broken magnet. Mine looked like yours. I put a little bit of epoxy on the broken sides of the magnet and also behind it, like you showed in your diagram. The only tricky part is that the magnets are really strong, so it can be difficult to line it up right, but mine wasn’t too bad. As long as you use proper epoxy like JB Weld (don’t use dollar store stuff), then the force of the magnet + epoxy will hold it in place really good.
It broke like this and now I am thinking to fill it with epoxy or erolite
Should I remove the broken pieces or just stick them together
Tbh just get a broken hoverboard and take a motor from that its not worth the time to do this half-assed fix (its never going to end up as good as it was)
Magnets should be replaced and its close to impossible to get matching ones imo there are no specs etc. A broken hoverboard can be bought for 20-50$
Damn those are tiny magnets in comparison to a onewheel hub motor. Uploading: 20200205_122122.jpg…
Hello,
I have convert an hoverboard like your video and it works great. Just tilt angle is not confortable. I wonder if I buy an dual flipsky vesc 4.20 with mpu 6050 if I could have stabilisation like ow xr.?
Bionic24 you have do this mod?
Uploading: IMG_20210512_180033.jpg… Uploading: IMG_20210511_163111.jpg…
Does the stock Hoverboard battery fit in its original shape? or do you need to reconfigure the cells so it sits flatter? Thx!
Hai Duke,
The original design has the battery protruding through the underside it was designed in this way. So yes the original design fits the standard configuration of the cells, but is not particularly pretty nor safe. I would recommend to reconfigure the cells, this is fairly easy and possible without spot welding. In this topic people discussed about the reconfiguration before. Together with that information I think you’re able to figure it out.
PS Here is the closed battery side version. Diy Onewheel Closed battery side by Nathan_I3 - Thingiverse
@Bionic24
Hi, have you thought about making a special firmware for the main board of the hoverboard. If you connect the mpu-6050, you can control the tilt. I started to learn this based on the EmanuelFeru FOC firmware. but more knowledge in programming is needed …
Hey guys,
I’m in the process of building a Onewheel out of hoverboard motors myself.
But instead of using the hoverboard ESC, I want to use two VESCs (Cheap FOCer 2).
I have them up and running on their own, and I have also connected them over CAN. The master can detect the slave, and I can program the slave through the master.
But I can’t seem to grasp how to actually let the master-vesc control the slave while in balance mode.
I’ve been trying to read up on things, trying to fiddle around in the Vesc tool, but I just can’t seem to get them to work together.
Does anyone have any experience with this kind of setup, and maybe could shed some light on this?
Thanks in advance!
Hi I use two hoverboard motor with vesc 4.2 dual flipsky for a diy onewheel. I have pb with pid balance or motor setup. For working dual motor you have to desable with of all uart or remote controller section. And active multiple vesc true in balance app.
Thank you very much! I will try it as soon as I get the chance!
Hi, I have a stupid question. If I don’t connect the Hall sensor, will onewheel go faster? Electronics would not know speed and could not limit it. Thanks
Correct, no offense. How would the board know the position of the wheel and balance you correctly and accurately?
You are right. But for electric scooter is this idea right?
No, hall sensors are just a more accurate way of measuring the motor’s position. If you don’t use the hall sensors the vesc should use back EMF to measure the rotor position. I think using the hall sensor is recommended as it gives much better control at low speed.
A vesc can use back EMF to find the rotor position.
Hi, I bought a hoverboard to build onewheel. But the hoverboard balances itself immediately after switching on. Do you have experience with such a board? Will it be suitable for the project?
Dual vesc is useful. not many? with imu.
I do not understand what you mean
