Hi everyone, I recently borrowed some exway atlas. And now here I am, I really need to build my own. Actually two, my girlfriend wants one too.
I would like your advice on whether it is fine like this, or what you would do differently.
My idea is that it can ride on a variety of terrain, mostly cycle paths in our forests, where there is gravel, asphalt and only beaten paths. I live in the EU in the Czech Republic, we have quite hilly roads here. And now the hard part, 80km range (about 50miles). I am 80kg (170-180lbs) and I would like to ride about 25-40km/h (16-25miles per hour). So I need solid performance and a battery.
Here is my proposed build.
DECK: MBS Comp 95 Silver Hex
TRUCKS: 2x MBS Matrix III CNC Truck System 12 x 420mm Black
: 8x MBS MATRIX III TRUCK/DECK SCREW 25mm
WHEELS:
HUB: 4x Disk MBS RockStar II
TUBE: 4x MBS Inner Tube
TIRE: 4x MBS T3 Tyre
BEARINGS: MBS Bearings 12mm*28mm (8pcs)
MOUNTS:
2x MBS MOTOR MOUNT ARM
2x MBS MOTOR MOUNT CLAMP M3
PULLEYs:
ENGINE: 2x Flipsky motor pulley 15T D-shape
WHEEL: 2x MBS Wheel Pulley - HTD 5M - 72T
: 10x MBS PULLEY SCREW - M4 x 60mm (RSII, RS Pro, RS Pro II)
FOR 682$
_____________________________________________________________________
MOTORS: 2x Flipsky BLDC Belt Motor Battle Hardened 6384 140KV 4000W
REMOTE: Flipsky Screen Remote VX2
VESC: 2x Flipsky 75100 Pro With Aluminum PCB Based on VESC
: Dual ESC Can Bus Connector Compatible with VESC
: Bluetooth Module 2.4G Wireless Based upon the nrf51_vesc project ESC: For VESC6 / VESC75
BMS: LLT 14S smart BMS with Bluetooth function UART communication 20A
CELLS: 14S9P = 126x EVE INR21700-50E 5000mAh - 15A
CHARGER: LLT Li Ion 14s 58.8V - 5A
FOR 800$
______________________________________________________________________
I’m most unsure about the control unit - VESC, whether it’s worth paying extra for something better (MakerX Go-FOC D100S), but it’s a lot more expensive. Then I don’t know about the BMS, I assume it’s better to bypass and use the BMS only for charging, but I don’t know much about recuperation, so that it’s safe to brake. If you set the Battery Current Max Regen in VESC: -20 A and it will be fine and it will brake safely and sufficiently.
And then the cells, I don’t know whether to use some 5000mAh 15A max (10A continuous) at 14S9P, that’s 50V*90A=4500W, or go to 4000mAh 40A (25A continuous), I don’t really know how much I need to get the maximum (peak) available amperage output from the battery.
I’ll use EVE, BAK or TenPower from nkon.nl, they’re around 2€ each.
Of course I know that I will need to buy some fishpaper, nickel strips, copper cables and probably some fuses and more.
Thank you very much in advance for your valuable advice and if anyone has something that would be useful for my build and you are near the Czech Republic, I will be happy to take it on for a reasonable price.
