Lately a lot of manufacturers have been making power/amperage claims that have caused discussion in the community.
One of the problems is that there is no standardized procedure for measuring the capabilities of the equipment in esk8. This can cause a lot of confusion since there is no way of making a fair comparison between components.
Example:
Manufacturer A claims that his ESC can output 60A continuous @ 50V.
Manufacturer B claims that his ESC can output 80A continuous @50V.
So ESC from manufacturer B is more powerful right?
Unfortunately unless we know all the testing parameters there is no way of telling.
What is not apparent in the previous example is that A classifies as continuous operation 5min of constant output with the ESC screwed on a huge aluminium block with an ambient temperature of 20C while manufacturer B 3min of constant output with a fan blowing on the case with an ambient temperature of 15C.
There is literally no way of comparing these two speed controllers using the manufacturer provided specifications.
So why not establish a standard of measurement?
For example welding machines have their current ratings measured in combination with the duty cycle.
So you may have the following different 230A welding machines.
230A @35% , 130A @%100
230A @60%, 180A @100%
Both machines are sold as 230A welders however machine nr.2 is capable of sustaining its output for longer.
Duty cycle is measured in a 10min duration at 40C ambient temperature.
So 180A @ 60% duty cycle means the machine can operate at 180A for 6min, cool down for 4min and so on.
Why not agree on a standard procedure for rating components?
Obviously there will be manufacturers that will not want to do so, since this would mean they would lose the ability to use bullshit ratings as a marketing tool but in the end these manufacturers should not be trusted.
Nobody buys a car or a motorcycle on unbased manufacturer claims, why do accept this in esk8?
