guessing wildly i wonder would switching frequency increase fidelity on current sensing and therefore help here?
Yeah, I am curious why the later spike though. There’s definitely no wheel spin happening.
That’s what I hoped the time constant thing would do, but what do you mean by switching frequency? Like Bldc?
I didn’t understand the time constant thing, if it’s at detection time i wouldn’t think it would affect runtime other than perhaps getting some more accurate detection in the first place of R and L values?
Switching frequency i’m also a little fuzzy on. I think when those words are used they mean the setting “zero vector frequency”
it’s what shaman had me enable.
and I think it prevents losing track of the motor at higher rpms? … but it’s on my todo to understand bettter.
if it’s what I think it is. it’s increases the “sampling rate” the wave form being generated on the phase wires. makes it higher resolution. at the cost of switching the fets at a faster rate.
so my wild guess stab in the dark idea is that the loop that checks current and adjust dutycycle would also increase frequency to match the new switchign frequency? but… idk… i’m pretty low confidence i understand this bit right.
I was mostly hoping to cunninghams law my way to an answer for you.
Ok so you already have it enabled though? If you learn more I’d be interested otherwise I guess I’ll try to dig as well. But seems straightforward enough, higher resolution in order to prevent the spike.
yah assuming it’s higher resolution of the measurement and control loop. but idk that it is.
and yeah I have it enabled but haven’t gotten back to really pulling on v5#1 since the change. also it’s 2wd so i don’t think i have the wheel slip related spikes.
I think the wheel skip spike is fine with TC, but I’m going to keep this in mind for the other spike if max wattage doesn’t help. Thanks.
For all the days it’s not working right I’m just like what am I doing
If it makes u feel any better my 4wd was flipping out on me last run i had. My motors starting squeeling at me and kicking in late. One side of dv6 had gone back to default settings . Then took a few attenpts at motor configuration again to get everything working properly. Very weird. I’m wondering if my two seperate loop keys plugging in seperately is catching up on me and fucking with Canbus.
In other news it’s hard to tell but the Hubba-hubs flare out ~0.7-1mm more than the Newbee pentagrams hence the vibrations my guess.
I’ll probably print a wedge and see how that goes.
This is the one found under FOC?
According to the note it’s apparently only available on hardware with phase shunts and from what I remember only the Trampa ones have that.
Thats called a draft angle for injection moulding.
Oooh TIL. So was it more a necessary thing with the mould process (i.e. not necessarily planned)? Either way it helps a lot in this case with a tighter fit.
Yes, with injection moulded parts a 0.5 to 3 degree angle is needed so the part can fall nicely out of the mould. So this angle is indeed necessary.
I’ve used a layer of gorilla duct tape to fill out dimensions b4 with good luck.
3dp maybe better, but when its just a bit needed i doubt a 1mm 3dp would hold up
That’s a great idea thanks! Yeah I was also kind of afraid something that thin wouldn’t hold up as well.
Ive come to the conclusion that some tires that are deemed shit is actually bad ID/OD fitment and can be rectified with some fine tuning.
Please tell this to my customer who wants “aggressive texturing” on their 0.2° drafted parting line
My 20s build is 2+ years old now and is the most reliable board I’ve ever built.
Nothing wrong with 12s, but statistically I’d bet those running HV are also doing crazy shit. And doing crazy shit breaks stuff
Edit
Only two sets of “major” work was done.
Had to add some welds to one pgroup that was going out of balance
Upgraded to jump drives
