I currently aim to ship out all current orders by the end of August and have DAVEGAs on stock afterwards. I’m getting the parts in big bulks now to make sure I don’t run out of anything. Just waiting for 100pcs of displays now.
I know I have kept you guys waiting and I’m sorry about it. I’ve been working on DAVEGA full-time since the beginning of July and I made a huge progress since. It really makes a difference if you can focus your full attention on a single project. These huge delays between order and shipping out will soon be a history.
Thanks. This is very strange. People have reported the same problem a number of times but so far it has always been an issue with the settings. Your settings look correct though so it must be something new.
And, sorry, just to be sure, you have the riding screen setup to show speed, right? It’s not showing battery/motor amps instead?
It would be really helpful if you could reset the session and then travel some known distance (e.g. 1 mile) and take a note of the distance measured by DAVEGA. That would tell us the ratio by which the DAVEGA speed/distance readings are off and will hopefully give us a hint about where the problem is.
I reset it, went out for a ride and it worked flawlessly, speed matched the Trampa wand inc temps etc, I had the canbus vesc setup wrong on the vesc tool as in the wheel size etc, even after correcting it, it was displaying the wrong speed till I reset the davega, not sure if that will explain it but as long as it’s working
That’s definitely not expected. Session reset does not affect the speed readings in any way. Have you maybe power cycled the VESCs in the meantime as well?
Anyway, I’m glad it’s working. Thanks for the update.
Would no load cause it, first few times I tested it by just lifting the board, I tried it again and readings are off but when with load, riding on the streets it’s reading perfect
Yeah, when I’m riding it matches my wand but without load it’s all over the place, definitely weird, maybe it’s lag time due to the length of cable, I’m really not sure
Ugh, that’s long. I’m sorry. It seems pretty random. For example, a package I sent to the US (Berkeley 94703) on July 21 arrived to NYC on July 26 and is already about to be delivered.
However, I also received a package from the US a few weeks back that took about 4 months (shipped with USPS).
I haven’t yet had a lost package though and I have sent out more than 100. It will arrive eventually.
