DAVEGA X: Gauging interest
For motor pulley teeth and wheel pulley teeth, you need to count what your wheel pulley and motor pulley have.
There is not such thing on Direct drives, otherwise, would have done so :wink:
Oops, I completely forgot about hubless :sweat_smile:
I also apparently missed DD = DirectDrive :sob:
Changed the motor poll to 14, top speed has been reduced by half.
Thank you guys
IIRC TB 6355 motors have their temperature wire switched with another wire on the connector. That’s why you don’t get a reading. Should be an easy soldering fix though, I suggest you search on this or the old forum to find someone who’s done it.
Thanks for the info! I’ll take a look around. When I messaged TB directly, they just said that the temperature sensors for this iteration of motors don’t work and will be fixed in the next one. I had assumed there was no fix so this is good to know.
The buttons are sold as waterproof, so I hope they are. I have had zero issues with water and the buttons. Also they have o-rings and a precision seat for the o-ring to make a good seal to prevent water getting under the button into the davgaX case.
Great to hear thank you!
Guys, I just want to say I’m sorry for keeping many people waiting. I was waiting for parts and also didn’t have enough time for doing the assembly because of other responsibilities. I now have everything on hand though and early next week I should be able to dispatch all orders that came in on Sep 17 or earlier. I will contact you with payment information soon.
More parts are on the way and the orders that came in after Sep 17 should be dispatched within 3 weeks from now.
Next week batch:
@Zeah
@GJF1
@rpasichnyk
@Janux-esk8
@Robin
@torqueboards
@Jbev
@JFA
@Shikaka
@monkey32
@magharees
The batch after:
@Skyart
Bigbrit
@Myke
@monkey32
thetaurean
@Dk-odense
@ixf
No worries man. Take your time :+1:
Why can’t everyone selling stuff in esk8 do this? Delays happen, but no one really cares when the creator communicates like this.
Thanks for the update, looking forward to these lil gems!
indeed. ordering my DaveGa X was painless and delivery was fast. even got pics of my order.
I am so freaking excited for this!
The metr pro unity is an upgrade to the stock BT module but you still can’t see speed and other data without the app on your phone, so the davega is only a telemenary screen right?
So really you need both for the best experiance right??:stuck_out_tongue_winking_eye:
If one ever comes out using bluetooth to connect, it would be so much easier to use :D.
I’m currently looking at making davega wireless but I was only going to focus on making the communication between the vesc and davega wireless. I already have a couple of transparent UART transceivers I need to test.
Just curious but why would BT make it easier to connect? I ask because I toyed with the idea of also making the uart BT accessible but dismissed it due to potential complexity and cost.
I already have a bluetooth module installed in my board, so it would be so much easier to connect it to the device, and have it work, instead of opening everything and installing something else. Plus for some people, both of their uart ports are used so we don’t really have any other option to do it.
It’s also an odometer, which is the most important feature to me. Mobile apps also have the odometer functionality but it only works correctly if you always have the app on while riding, which may not be the case. Davega, on the other hand, is always on while you’re riding.
I personally use both davega and Metr. While there’s some overlap in the functionality, they complement each other nicely. Metr’s logging is awesome for troubleshooting. It’s also great for changing your VESC settings quickly. Davega is better as live data monitor and odometer.
Hmm maybe I’ll order some BT chips too then and see where that takes me.
