These could be nice, but I don’t know how secure is the cap on them.
those use the glass fuses right?
can we use glass fuse in our builds?
if it is good enough for a Carnival King cotton candy machine then it is good enough for me.
idk possibly an issue but who knows!
I have one of those I can send it ur way if u want, and all the fuse u need until end of time
No idea either, I was thinking I only saw those types on devices using AC power.
Daly BMS charge-only wiring diagram. The BMS is only on the charge circuit. The discharge circuit is entirely separate. The ESC is wired straight to the B+ and B- (battery positive and negative) leads of your battery, bypassing the BMS.
Let us know how the Daly programming is, hard to imagine its worse than LTT/ANT but I’ve been wrong before.
ANT isn’t that bad though.
Its not great
UPDATE! I got the bms wired properly last night!!!
Anyone know what app is used for the Daly smart bms?
Found it!
Got a link for the smart Daly?
I got them from Alibaba, do you need one? I have extras
But this is the store I think
Changsha Deligreen Power Co., Ltd.
Search it in alibaba and send an inquiry
How well do these balance packs?
They don’t have very high balancing current but if you are using good quality and consistent cells it should be fine.
If you need something to manage more rogue cells you may want to look into an LLT smart BMS, as it can balance even when not charging.
Mine doesn’t balance at all, despite saying “with balancing”.
Wouldn’t be surprised if all of them don’t balance. Most users don’t bring brand new packs out of balance just to test the BMS.
