Feb 2020 updates at post 14
Hey ESK8.news,
Long time reader from the old forum. Finally posting the “build” or rather, the series of upgrades from this summer. This was my experience starting out with ditching the car and adopting esk8 for 100% of my philly commuting this year. Ive been here/old forum for 100% of the motivation and info
Stumbled upon the boosted board in April of this year. Found the old forum and knew that’s the route Id wind up. Decided to buy a cheap board to get started with, learn on and see if I wanted to make a $1500+ investment in Esk8.
I used to skateboard when I was 15-16, that was 15 years ago. Bought a loaded vanguard and pushed kicked it around for a month. In May, pulled the trigger on an ownboard when they were on sale
Ownboard W1AS - While I think ownboard makes a great starter board, I very quickly outgrew it.
$379 stock on sale. Immediately added new 90mm 74a front wheels, new shorter riser pads, caliber trucks and new bushings and eventually a cheapy moose deck from amazon.
The budget board route does work, but the deck on the W1AS was terrible for philly. And the combination of standing above the trucks, on a stiff deck, with hub motors… it limited me to just a few blocks between feet numbness
The deck allowed me to get the trucks out from right under my feet and the ride did improve.
Next, about 6 weeks later, I learned my lesson for buying a $35 plywood deck from amazon. Crossing trolley tracks at low speed, the deck snapped under me and sent my ass to the ground. Fortunately this was at low speed and I wasn’t seriously hurt.
Replacement was a proper longboard deck with a mix of bamboo ply and fiberglass from sector nine. On closeout sale at $65. Plus, at 35 inches, I can carry the board from the front truck without it touching the ground (im only 5’9") which is a big plus since this is my daily commuter. Heres the new deck next to the stock W1AS.
I wanted to reinforce the structural integrity of the deck, especially where mine fractured. Also had no plans for drop through, so filled the holes.
Sanded to raw wood and laid up about 3mm of fiberglass. I only have this photo of a final coat of finish epoxy.
And yes, im laying up epoxy and sanding fiberglass in the bathroom of my 1BR apartment
(girlfriend wasn’t thrilled)I had intentions of exposing the sparkle black color I added to the epoxy. But I was tired of having the bathroom in disarray and threw things together. My Ownboard enclosures did not fit the width of the smaller deck, so I 3d printed some up quick with PLA+. I used some chemleaon vinyl on the bottom of the board to finish off the sanded epoxy FG underneath. About 3mm of thickness under the truck mounts that tapers out to 1mm in the center. Added a single layer of FB to the top to over some strips that built up the concave a bit in the rear
The board rode great. A bit of flex in the new deck was retained even after reinforcing with the fiberglass. But this is still an ownboard drive train. Heres a pic from riding out to the Made in America festival in Philly. This is likely the last time I rode without a helmet. I don’t leave without it now
I rode it like this for a solid month. But at this point, I had been riding for a few months and was really starting to get comfortable. I was really starting to notice that the rear hubs were creating more sketchy situations than Id like. I was sliding the back wheels continuously around turns when not intending to because of the lack of traction and thane depth. In addition, the worst was several scenarios where I was cruising around 22mph and would have to jump on the brake… Well Id mash the remote to 100% brake, and spend the next 10 seconds contemplating where I wanted to splat myself on the upcoming obstacle. Braking performance at high speed was scary bad, it was time for a change.
The build finally,
I had no plans to do this. But the need for tunable braking performance and better traction was high. I decided to strip the Vanguard build I had slowly been gathering parts for. I had everything but a battery, as I still haven’t pulled the trigger on a spot welder. So I combined them to the 10S2P 30q I had from ownboard
Caliber 2 44 rear/50 front
Boardnamics standard mounts
6355 x2 190kv motors from @torqueboards
x2 4.20 flipsky VESCs on sale for $50 ea
flispky antispark for now
@dickyho 36T pulleys
Not a ton to show off here, and I didn’t take many pics while building. Things were way way tight in the VESC enclosure I made.
Excuse the broken belt, I had way overtightened one and broke it first day.
For those nervous about there first build, the VESC configuration is really easy - this was probably the most intimidating step for me, and it was by far one of the easiest
VESC settings:
FOC
motor max 40
motor min -33
Batt max 14 per VESC
Batt min -14 per VESC (corrected)
Fast forward a week like this and I picked up some 97mm ABEC reflys. Rebuilt everything including the enclosures with new designs and ABS filament. Brightened the board up with some new Vinyl too. Cut the rear hanger to allow the use of a bearing on the dickyho pulleys too. Shredlightz for the night riding. Ditched the 5mm bullets for MR30 connectors.
Off to get some better finished pictures of the board as it sits now. Will update in a bit!
What I learned, what takeaways I have following the 1st build and my intro to esk8 in general:
- **Buying a cheap board first - **going the cheap route can work, but manage your expectations. Buying the Ownboard was both good and bad. Good because it gave me an opportunity to try esk8 for under $400. I saw exactly one esk8 in philly before buying my board, and have never ridden one. If it was just an occasional cruise to the store, that board may have been fine in stock form. But given the road quality in philly (more on that in a moment) and the ride frequency, this just wasn’t good enough for the amount of time my feet were on it. On the bad, the ownboard is essentially trash right now. I guess i could use the hubs and ESC to make a small deck for friends, but im not pleased with the braking performance. Will likely use on another project, but theres essentially zero resale value. Bad, I grew out of it quickly
-Road Quality - if you live somewhere with beautful streets, ride whatever the hell you want. If you live somewhere that it snows and the roads are always shit, do not waste your time with hub motors. I had researched like crazy to find people differentiating the feel between hub motor and belt drive. Most described it as a noticeable improvement in ride quality that wasn’t earth shattering. That was my experience, big increase in ride quality and control with the 90mm abec clones. Switching to the 97mm ABEC reflys changed everything. For those who are in the position i was, let me tell you : The ride quality of 90mm hub motors compared to a belt drive with a nice set of premium wheels is unapologetically horrendous in comparison. The ABEC 97s are like riding on a pillow. Even the worst of cracks are muted with a knock rather than a pain induced crack. If youre in an airea with bad roads, dont even mess with hub motors. Spend the $75-$150 on a nice set of premium soft wheels for your belt/direct drive setup and skip the hubs all together. They have no place on these streets
- Components - Dickyho pulleys are very affordable and do a great job. I ran them initially in bolt on setup with no bearing on stock caliber trucks. This was not great, the inside of the pulley rubbed the truck from the deflection created and I routinely could here thigns when really leaning into a turn. I cut 9mm from each side of the caliber truck and am currently using them with the bearings. Now im looking for a replacement truck because I don’t trust the axles. Will upgrade to something CNC with shoulder bolt axles soon.
The poor man buys twice this is worth restating and its something Ive learned and sometimes continue to experience over the years. Its hard to commit big spending when you are just getting into something without experience on what you really need vs want. But this statement will always be true.
Upcoming to finish this: Samsung 30q 10S3p flat pack and new single enclosure, ditching bolt through pulleys for true push fit, 40T pulleys for the 97s. CNC trucks
Ill add to this later when I think of more. Thank you to everyone on the forums for your gracious advice, shared builds and endless knowledge.
Bill
Also, Im accepting nominations for 2019 build of the year - most vanilla edition
Snapped two pics today while the weather was decent:
