So here’s the story, I built a guy a 12s4p pack, installed it onto his dream board and everything went well, until he tried to plug in a 10s charger onto the pack and it killed the BMS. There was no smoke or anything but it for sure killed the bms in a way.
The bms since then won’t charge anymore with a normal 12s charger and I think a diode or a fuse blew but I’m no electronics major so would like some insight on this topic
I have a d140 that is about 30 cycles old. It was plugged into @torqueboards 4A charger for the second time and I believe something let go. I fell asleep with it plugged in/charging and when I awoke it was less than 50V. Thought it was weird and went to check if it was plugged in. Light was green but voltage was down to below 49V.
I unplugged the bms and confirmed that all p-groups were charged to the same value, and the value is equal to the voltage measured through the charge port. I confirmed that there is continuity on the charge port + and - . Also have confirmed the ground is good for the BMS. I have also tried a second 1.5A charger.
Is there anything else that I could check or measure to confirm what went wrong?
Did you charge/discharge your pack multiple times after that? If yes does the bms cut off always at the same voltage?
50V would actually be not that bad.
That’s 4.17V per cell. So your bms cut off at 4.19-4.2V and after that the voltage will drop a bit. That’s totally normal.
Same the other way round. If you discharge your cells the voltage drops first more and as soon as there is no load the voltage will rise up again.
I did not discharge at all. More to the story, though.
P-group voltage was all 4.08V exactly. Loop key was still in and metr/vx2/escapes all on drawing power. I assumed it had got to cut off voltage and not restarted when voltage dropped. It was 48.9 at last check when the charger would not kick on.
I just went to check voltage drop overnight. It was only around .2V. I decided to check the charger again and it’s working. I haven’t moved a single wire since last time I checked. Really stumped now. I could believe a bad solder joint, but it’s not even been breathed on since last check.
I have not, but I have monitored both chargers with metr and a plug in volt meter. I’ve been riding multiple times a day, so have really been paying close attention. The 4A just charged up the last 1V and is fully charged and reading 50.4V.
I’m going to ride it and see if it keeps performing normally. Have a Daly on order to be here by the weekend just in case.
