It’s the same as the Paris logo on the baseplate, it’s purely cosmetics in the manufacturing (the N doesn’t make the part suck, it’s just a weight saving pattern)
How about you make your own CNC footstops and offer something to the community. Oh wait you can’t? Then STFU
Lol. What would you like?
if u don’t like my product, just don’t common here with BS reason. If u think my product wasn’t high end enough and don’t deserve put name on it. Then pay me tho, I make u something engrave u name, " keyboard fighter" on it.
I agree, idk what @sleepless agenda is, but I believe in not trashing a product until you try it
It makes even less sense since the criticism is about the looks, not the functionality. These look great. If you don’t like an N, don’t buy it.
It’s nicely machined and seems good quality, but depending on your stance you might find that it needs a bit more adjustment range.
You can see mine is mounted on the piss a little bit to get it at the angle i wanted.
Mah dude would you be ashamed to drive a Mercedes-Benz or a Rolls Royce? Because last time I checked the silver Arrow and the Muse have no other function than aesthetic (my bad, it is a visor to run over riders and bikers tho right)
Both are literally named after their original founders. Many big manufacturers do it, same for other activity fields.
For a dead simple footstop I fail to see how the N embedded shape could make it fragile in any way and compromise the quality of the product. It actually helps make double triangle sections, which make it stiff with supports.
TLDR : I see your point but it doesn’t apply to @Ean.esk8 product, and I’m not even a buyer there.
OP keep up the good work.
Those Bustin and Loaded boards are also just so trash the way they laser burn logos into their decks and use stylish grip tapes
Pure filth.
You can see in the photos how far it can be adjusted.
Also how far it could run down a deck.
was it at its max?
cheers
Yes it was at its max and installed on the piss to gain more angle. There is plenty of adjustment north to south, just needs a bit more in the angle department
ah nice
def interested in one
what size tire they fit? 5 point mount pattern looks like those kegel spokes? or maybe u have ur own pulley adapter? im curious
it are different adapter, only fit our gear drive currently.
another gear drive on the block soon™? nice to have options
