This is a personal project, and one that I am just now about to begin. And in the spirit of adventure:
“Even the longest journey, begins with but a single step.”
-Bill Nye, in a really old guy’s voice
It starts with something very special, a LaCroix Prototipo deck and enclosure, that has never been used or built into. No model markings, just plain. From, what I understand, when they offered a DIY set of sorts prior to the DSS60 and DSS50+ models.
I picked this up locally from @Brently, and was stunned to see it. @EDness and @jack.luis were there as well, and it seemed like I was in good Prototipo company. It was inspiring.
I will list below the knowns and unknowns (more or less) of what will likely go into this build.
Deck: Leaving it with a mostly stock appearance. I’m going to lightly sand it and seal it with a few coats of spar urethane. I did some tests, and I’m happy with the finish after 4 coats. It seems like it’ll give it a nice semi-gloss finish, and preserve the wood grain and prevent some yellowing over time.
Battery: 12s5p in P42A, either with a FlexBMS Lite, or a prototype charge-only BMS that a friend designed. Failing those, a Daly 12S because they carry their weight.
ESC: Xenith. I mean, it’ll fit, and I’ve tested it. I have a spare Unity that I can swap in just in case, but I’ll go with the Xenith first…after I fix the thermal tape issue.
Trucks & Mounts: I’m likely going with the kit that @EboardSolutions sells: QUALITY MECHANICAL EMTB KIT – ElectricBoardSolutions and just grab a couple extra hubs, and the yellow bushings.
Wheels: Trampa Urban Treadszzsz
Motors: FS BH 6384 190kv
Other Electronics:
DRI Xenigotchi + GPS unit, OSRR Bruce remote.
Questions:
LaCroix sells both the Prototipo motor mounts, and the 62t wheel pulleys. Are these things I should go for? Or stick with the 66t pulleys and the mounts that come with the EBoardSolutions kit? I’m assuming that’s what they use on the Flux boards, so I’m glad to use them. Just unsure of what to order at the moment.
Would the 66t pulleys have adequate clearance with the 6.5" tires?
